[GRASS-user] db.in.ogr and v.db.join
The problem is that the new column is not conncted to a vector, infact:
db.dropcol -f voti_province colum=cat
Forcing ...
WARNING: Deleting <cat> column which may be needed to keep table connected
         to a vector map
ERROR: Column <cat> not found in table
I don't know if I do something not correct...
Thanks
leonardo
On Tue, Oct 23, 2007 at 10:04:12AM +0200, lami@faunalia.it wrote:
I'm testing the new databse commands on GRASS 6.3 cvs and I find a
problem
in db.in.ogr.
I'm using SQLite database, when I use db.in.ogr with a cvs or dbf table
Grass create the new table on .db SQLite file but it adds a first column
called "cat" that are not present in the original table.
This is strange since the script contains
# get rid of superfluous auto-added cat column
db.dropcol --q -f $GIS_OPT_OUTPUT colum=cat >/dev/null 2>/dev/null
(the cat column is added in the first place since v.in.ogr is
used, then db.dropcol is called).
It appears that db.dropcol fails.
Try to run
db.dropcol -f yourtable colum=cat
This will show the error.
grassuser mailing list
grassuser@grass.itc.it
Leo,
congrats - you found a bug in db.dropcol :slight_smile: Fixed in CVS.
While doing that, I have also fixed the case that a "cat" column
is already present in the original table (DBF file from a GRASS exported
SHAPE file). Also in CVS (db.in.ogr).
thanks,
Forcing ...
         to a vector map
Thanks
leonardo
problem
in db.in.ogr.
Try to run
View this message in context: http://www.nabble.com/db.in.ogr-and-v.db.join-tf4675839.html#a13372418
