I have one location which has the coordinates/projection for five themes,
so I used v.in.ogr and v.in.e00 to load those data. I then converted the
.dbf files to .csv, created a single SQLite database, and imported all five
tables in the single db:
[rshepard@salmo /usr4/grassbase/Oregon]$ sqlite3 oregon.db SQLite version 3.6.20
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> .tab
dams highways huc lentic lotic sqlite>
Reading the db.in.ogr man page suggests that the module will extract a
specified table from a named database based on the SQLite example on that
man page:
db.in.ogr dsn=$HOME/sqlite/sqlite.db db_table=census_raleigh output=census_raleigh
I tried to import all 5 tables simultaneously by putting the set of
db_table/output specifications on the single command line. This seemed to
have imported the first two tables, but not the last three. Thinking none
were imported, I tried each individually with the following results:
GRASS 6.4.0svn (Oregon):/usr4/grassbase/Oregon > db.in.ogr
dsn=/usr4/grassbase/Oregon/oregon.db db_table=dams output=dams
ERROR: Table <dams> already exists
dsn=/usr4/grassbase/Oregon/oregon.db db_table=highways output=highways
ERROR: Table <highways> already exists
dsn=/usr4/grassbase/Oregon/oregon.db db_table=huc output=huc WARNING: Column name changed: 'cat' -> 'cat_'
ERROR: Input DSN <huc> not found or not readable
dsn=/usr4/grassbase/Oregon/oregon.db db_table=lentic output=lentic
ERROR: Input DSN <lentic> not found or not readable
dsn=/usr4/grassbase/Oregon/oregon.db db_table=lotic output=lotic WARNING: Column name changed: 'cat' -> 'cat_'
ERROR: Input DSN <lotic> not found or not readable
Where do I start looking for the reason(s) the latter three tables will
not import?
Rich
