Hi list,
is it possible to use the old dbf driver instead of the new default sqlite driver in GRASS7?
Levente
Hi list,
Levente
On Wed, Jul 3, 2013 at 3:17 PM, Levente Juhász <jlevente89@gmail.com> wrote:
Hi list,
driver in GRASS7?
You can set the default database connection with db.connect, e.g.
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
Note that the dbf/ subdirectory in the mapset must exist or must be
created by the user.
Markus M
Levente Juhász wrote:
Hi list,
Hi!
driver in GRASS7?
I think its as easy as "connecting" to it, i.e. (from the manual)
It "was" the default DB driver in earlier GRASS versions [0], including all
series 6.x (I think... ?). Nowadays, that is in GRASS 7, the default driver is
SQLite [1].
Best, Nikos
[0] <http://grass.osgeo.org/grass64/manuals/grass-dbf.html>
[1] <http://grass.osgeo.org/grass70/manuals/grass-sqlite.html>
MarkusM:
I think that usually it gets created as needed automatically. There
may still be a few places it doesn't, if so file a ticket to fix..
(did a long audit for that in grass6 some time ago, tested in grass7
last week & it was automatically created as needed.)
Hamish
Thanks for the replies.
db.connect would do what I want, but I think my issue is a bit more tricky. Actually, I use GRASS7 as a backend for some WPS processes, and as it seems to me: every WPS process creates a temporary workspace. I may be able to run v.db.connect via WPS, but it would have effect on a vector map (which is also temporary), so it has nothing to do with the next process I want to execute.
The reason I wish to use dbf driver instead of SQLite is the following: There’s a package called Geo-MHYDAS, which had a module m.definput 1. This module gives the error message: ERROR: Sorry, but only dbf driver accepted.
So that is why I want to find an “universal” solution.
Any thoughts?
Levente
2013/7/3 Hamish <hamish_b@yahoo.com>
MarkusM:
created by the user.I think that usually it gets created as needed automatically. There
may still be a few places it doesn’t, if so file a ticket to fix…
last week & it was automatically created as needed.)Hamish
execute.
There's a package called Geo-MHYDAS, which had a module m.definput [1]. This
So that is why I want to find an "universal" solution.
Any thoughts?
Yes:
which sets the default database connection to dbf. Note the difference
between db.connect and v.db.connect. In your case, you would need to
run db.connect immediately after the mapset is created, before any
vector data are imported in the temporary mapset.
HTH,
Markus M
Levente[1]:
http://www.openfluid-project.org/resources/docs/mhydas/en/segmentation/html/m.definput.html2013/7/3 Hamish <hamish_b@yahoo.com>
MarkusM:
I was wondering about re-compiling GRASS7. I don’t know if it is possible to compile it with the dbf connection as default. I think that would solve my problem. What do you think? Does it make any sense?
If so, can you point to a direction where I can start doing this?
Levente
2013/7/4 Markus Metz <markus.metz.giswork@gmail.com>
execute.
Any thoughts?Yes:
db.connect driver=dbf database=‘$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/’
vector data are imported in the temporary mapset.HTH,
Markus M
Levente2013/7/3 Hamish <hamish_b@yahoo.com>
MarkusM:
Levente wrote:
I was wondering about re-compiling GRASS7. I don't know if it is
see include/dbmi.h: #define DB_DEFAULT_DRIVER "sqlite"
and include/temporal.h: #define TGISDB_DEFAULT_DRIVER "sqlite"
change to "dbf".
typically just running db.connect early on to set the default database for the mapset in the $MAPSET/VAR file is enough. (or pre-seed that VAR file into the new mapset dir yourself)
Hamish
2013/7/4 Hamish <hamish_b@yahoo.com>
possible to compile it with the dbf connection as default.see include/dbmi.h: #define DB_DEFAULT_DRIVER “sqlite”
and include/temporal.h: #define TGISDB_DEFAULT_DRIVER “sqlite”
The TGISDB_DEFAULT_DRIVER can not be set to dbf. It works only with sqlite and postgresql (pg). But i am absolutely sure that you do not need to set the TGIS default driver.
Best regards
Soeren
change to “dbf”.
Does it make any sense?typically just running db.connect early on to set the default database for the mapset in the $MAPSET/VAR file is enough. (or pre-seed that VAR file into the new mapset dir yourself)
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
