I have a vector of data points that I imported from a CSV file (which was created with R). When I use v.in.ascii, no DBF file is created. I basically need this file so I can assign different colors to data points based on the value of the datapoint. The vector is imported correctly, but the DBF is not created.
v.in.ascii -n input=‘/Users/ryan/Desktop/Desktop Stuff/ems/responseTime.csv’ output=response format=point fs=, skip=1 columns=‘y double, x double, z double’ x=2 y=1 z=3 cat=0 --overwrite
What am I doing wrong? I have attempted this with both the GUI and the command line and both with and without the quotes as suggested in a previous post. DBF files for the other vectors I imported (from ESRI) are showing up though.
Ryan
created.
v.in.ascii -n input='/Users/ryan/Desktop/Desktop Stuff/ems/responseTime.csv'
output=response format=point fs=, skip=1 columns='y double, x double, z
double' x=2 y=1 z=3 cat=0 --overwrite
though.
Just a guess, but are there only the x, y, and z co-ordinates in the CSV file? If there are no other fields and you're creating a 3-D vector as here then perhaps it tries to be clever and skips creating the database table?
I would suggest leaving out the "z=3". If you are using the z co-ordinate as an attribute and want it to be in the database then it doesn't really make sense importing it as a 3-D co-ordinate. Also I notice it should be considered (IMHO) a bug, or at least a documentation bug in v.in.ascii that it automatically creates a 3-D vector if you specify the z= option, even if the -z flag has not been specified - what's the point in having the -z flag anyway if specifying z= automatically assumes you want a 3-D map?
Does leaving out z=3 lead to any success?
Paul
you are doing nothing wrong, the table is just created if needed. See
http://www.nabble.com/v.in.ascii-create-a-dbtable-tf3531086.html#a9854181
Maybe would be good to mention it in man pages of the module.
Martin
2007/7/23, Ryan Rosario <uclamathguy@gmail.com>:
created.
Stuff/ems/responseTime.csv' output=response format=point fs=, skip=1
columns='y double, x double, z double' x=2 y=1 z=3 cat=0 --overwrite
though.
Ryan
grassuser mailing list
grassuser@grass.itc.it
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Ryan Rosario wrote on 07/23/2007 07:40 AM:
If you also have attribute columns, you have to define them (columns
parameter).
See
g.manual v.in.ascii
for an example (eg, Example 5).
PS: Unrelated - for table only input I have added 'db.in.ogr' to GRASS
6.3-CVS which
imports DBF, CSV etc.
ITC -> dall'1 marzo 2007 Fondazione Bruno Kessler
ITC -> since 1 March 2007 Fondazione Bruno Kessler
Martin Landa wrote on 07/23/2007 09:32 AM:
Done.
Thanks for the suggestions.
I tried that and it did not work. I added an extra column to my data file called category and exported it to CSV. I then read in the vector using
v.in.ascii input=‘responseTime.csv ’ output=response format=point fs=’,’ skip=1 col=‘y double, x double, cat int’ x=2 y=1 cat=3 --overwrite
I did this both in the GUI and command-line and I also deleted the previous vector in case there was garbage left over.
v.info response shows no dblinks.
Is there something else I can try?
Ryan
On 7/23/07, Martin Landa <landa.martin@gmail.com> wrote:
Martin
created.
though.
Ryan
Martin Landa <landa.martin@gmail.com > * http://gama.fsv.cvut.cz/~landa *
![Get Thunderbird! Get Thunderbird!]()
Can you post the first two lines of you CSV file? Otherwise the problem
is hard to understand. So far you still don't define any attribute columns,
hence, no DBF (or other table) is generated.
Ryan Rosario wrote on 07/24/2007 09:26 AM:
using
v.in.ascii input='responseTime.csv ' output=response format=point
fs=',' skip=1 col='y double, x double, cat int' x=2 y=1 cat=3 --overwrite
v.info <http://v.info> response shows no dblinks.
Ryan
Perhaps I am not understanding what you mean by defining attribute columns.
Below are the first two lines of my csv file.
Latitude,Longitude,Category
34.420757,-119.685126,1
Thanks again,
Ryan
columns,
using
Ryan
View this message in context: http://www.nabble.com/dbf-File-not-being-Created-with-v.in.ascii-tf4127648.html#a11776634
