[GRASS-user] DBMI-DBF driver error
I have a problem working through the DBF driver example on pp 174-175
of Neteler & Mitasova with the North Carolina dataset. I''m running
version 6.3.0-4 under Windows Vista. The first two commands execute
without any obvious errors when run from the bottom window of "GIS.m".
But the third command has problems.
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
db.connect -p
g.copy vect=roadsmajor,myroadsmajor
Output from db.connect -p is
     river:dbf
     database:'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf
     schema:
     group:
Output from g.copy vect=roadsmajor,myroadsmajor is
     Copy vector <roadsmajor@PERMANENT> to current mapset as <myroadsmajor>
     DBMI-DBF driver error:
     Cannot create dbf database:
'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
     Cannot open database
''C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf'
     no database is open
     Unable to copy table <myroadsmajor>
     Cannot copy <roadsmajor@PERMANENT> to current mapset as <myroadsmajor>
I've checked and the file
'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/roadsmajor.dbf'
does indeed exist. What am I doing wrong?
Thanks in advance.
Matt
Any suggestions on what I may be doing wrong?
db.connect -p
    river:dbf
    schema:
    group:
    no database is open
Thanks in advance.
Matt
Matt,
db.connect -p
    river:dbf
("river" this is just a typo, no?)
    schema:
    group:
Does the directory exist?
If no, can you create it manually?
    no database is open
Thanks in advance.
Matt
grass-user mailing list
grass-user@lists.osgeo.org
You are correct. 'river.dbf' is a typo. I did a cut and past, but
the first character of the first line in the "Output - GIS.m" window
always appears a couple of line up and to the right of the printer and
"X" icons: it should have read "driver:dbf".
The directory 'C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf'
does exist.
This is probably grasping as straws, but could the difference between
forward slash and back slash be important? If I open a Windows
Command Prompt window (a DOS window) and type
     cd C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
I go to the correct directory. If I then type dir in the Command
Prompt window, I see the directory listing.
BUT if I am back at the root directory (c:\) and type
     dir C:/Users/Matt/Documents/GISdata/nc_spm_08/PERMANENT/dbf
I get an error message. Repeating with the back slash gives the
correct result in both cases. For shorter examples "dir c:\" works,
but "dir c:/" does not work (invalid switch). Depending how GRASS and
Windows interact, might this be a problem?
On Mon, Jan 19, 2009 at 4:49 PM, Markus Neteler <neteler@osgeo.org> wrote:
Matt,
db.connect -p
    river:dbf
    schema:
    group:
    no database is open
Thanks in advance.
Matt
I'm still trying to understand why I can't get dbf related commds to
work in the Windows version running under Vista. If I run the
database test from the GUI (Databases > Manage database > Test
database), I get reams of errors starting with:
     db.test test=test1
     create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
     Cannot create dbf database: '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
     Unable to open database <'$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'>
     EXECUTE: ******** ERROR ********
     insert into grass_test1 values ( 1, 123.456, 'abcd' )
     insert into grass_test1 values ( 2, null, 'xxx' )
And so on.
Taking another approach, I tried using the GRASS plugins in QGIS. In
QGIS I can display the roadsmajor map from the North Carolina dataset
(see details at beginning of this thread). Using the QGis "Open
Table" icon I can open and move around the dbf file. However, the
"Start editing" button is greyed out and does not work. So, the file
exists. I'm running with administrator privileges.
Is anyone successfully working with dbf with Grass 6.3 under Vista?
does exist.
Matt,
db.connect -p
    river:dbf
    schema:
    group:
    no database is open
Thanks in advance.
Matt
