I run into this issue today:
r.to.vect input=tty output=tty type=area --o
Extracting areas…
Writing areas…
dbmi: Protocol error
ERROR: Cannot insert new row: insert into tty values (3968805, 12, ‘’)
Running db.connect -p I found out that my database was dbf. I’m running GRASS 7.1.svn (r65027). Naive question: default database is not sqlite?
db.connect --help
Description:
Prints/sets general DB connection for current mapset.
Keywords:
database, attribute table, connection settings
Usage:
db.connect [-pgcd] [driver=name] [database=name] [schema=name]
[group=string] [–help] [–verbose] [–quiet] [–ui]
Flags:
-p Print current connection parameters and exit
Substitute variables in database settings
-g Print current connection parameters using shell style and exit
-c Check connection parameters, set if uninitialized, and exit
-d Set from default settings and exit
Overwrite current settings if already initialized
–h Print usage summary
–v Verbose module output
–q Quiet module output
–ui Force launching GUI dialog
Parameters:
driver Name of database driver
options: ogr,sqlite,dbf
default: sqlite
database Name of database
default: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema Database schema
Do not use this option if schemas are not supported by driver/database server
group Default group of database users to which select privilege is granted
I’m puzzled.
madi before massive morning coffee.
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
