[GRASS-user] Defining color table rules- other classes
Greetings
I have created a color table and defined colors for classes between 0-20. But, when I export It (as geotiff), it also defines colors for classes that does not exist (all black) or even for classes between 0-20 that does not have any pixel with that value. Is this expected?
Thanks
Luis
On Mon, May 16, 2011 at 1:09 PM, Luis Lisboa <luislisboa1975@gmail.com> wrote:
Greetings
gdal does that, because the geotiff format requires an entry in the
color table for each value in the range of the selected data type (or
no color table at all)
Markus M
So, it also creates an “black” entry for values from 21 til 255 right?
Thanks
Luis
On Mon, May 16, 2011 at 12:38 PM, Markus Metz <markus.metz.giswork@googlemail.com> wrote:
Greetings
Markus M
On Mon, May 16, 2011 at 2:44 PM, Luis Lisboa <luislisboa1975@gmail.com> wrote:
So, it also creates an "black" entry for values from 21 til 255 right?
Yes, because the geotiff format requires an entry in the color table
for each value in the range of the selected data type, here apparently
Byte which ranges from 0 to 255. If the valid classes would range from
20 - 40, the color info for 0 - 19 and 41 - 255 would be set to black
(0:0:0) by gdal in the produced geotiff file.
wrote:
> Greetings
> 0-20.
> that
> not
Markus M
