Greetings
Is it possible to define a Environmental variable for Windows, like GDAL_DATA, like this in a Python Script?
os.environ[‘GDAL_DATA’] =
Is this possible? does this work?
Thanks
Best regards,
Luisa
Greetings
Thanks
Best regards,
Luisa
GDAL_DATA, like this in a Python Script?os.environ['GDAL_DATA'] = <PATH>
Yes.
However, as each process has its own environment, it only affects the
process running the script and any child processes spawned from the
script. You can't modify the environment of other processes, e.g. the
process which invoked the script.
Hi Glynn
For instance if I define GDAL_DATA like that, If in the same script I run grass.Popen(<command to external gdal executable) is that defined GDAL_DATA path applicable?
Thanks
2011/3/31 Glynn Clements <glynn@gclements.plus.com>
GDAL_DATA, like this in a Python Script?os.environ[‘GDAL_DATA’] =
Yes.
script. You can’t modify the environment of other processes, e.g. the
process which invoked the script.–
path applicable?
Yes.
