[GRASS-user] Defining Partial Drainage Basin
   I want to limit my analyses to that portion of the basin that drains into
a specified location along the main creek. Which module will allow me to
define a partial basin with this point as the outlet?
Rich
   Got it. r.water.outlet, after running r.watershed.
   BTW. is there a readily available source for learning how to interpret the
output maps of these various terrain/hydrological modules?
Rich
A quick tip regarding r.water.outlet (you may have noticed this already)
The module creates a new raster covering the whole analysis region with two possible values: 1 for all cells draining into the outlet, and 0 everywhere else. If you do r.to.vect straightaway, youĺl get a vector containing two polygons...
I always run r.null setnull=0 on the r.water.outlet result first. This insures that r.to.vect leaves you with just the drainage area.
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
everywhere else. If you do r.to.vect straightaway, you?l get a vector
containing two polygons... I always run r.null setnull=0 on the
Micha,
   I'm under a deadline to finish the current project, and nothing seems to
be working correctly for me.
   I just ran r.water.outlet using the drainage (aspect) map created by
r.watershed. The output is a yellow rectangle that the legend tells me
represents '0'; that is, there're no cells in the calculated basin.
   g.region -p reports:
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: grs80
north: 1334420
south: 1279150
west: 769190
east: 819260
nsres: 10
ewres: 10
rows: 5527
cols: 5007
cells: 27673689
   The command line was:
r.water.outlet drain=aber10m.drain basin=lockie e=795542.95 n=1308323.52 --o
   I can send copies of aber10m.drain and lockie. It makes no sense to me
that such a simple run fails to define the partial drainage basin. Any help
or ideas you offer will be much appreciated.
Rich
In order for a basin to be delineated correctly, the pour point has to
be in a high accumulation area (I once heard the expression synthetic
river...)
Well, put your pour point on top of the accumulation map and see if
it's on top of the river. If not, change your easting and northing
coordinates appropriately. If you come from ArcGIS world, they have a
tool called Snap Pour Point that does that. I recall doing something
similar in grass using v.distance and a stream raster...
Good luck
Daniel
On Wed, Feb 10, 2010 at 4:22 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Micha,
zone: 0
datum: nad83
ellipsoid: grs80
north: 1334420
south: 1279150
west: 769190
east: 819260
nsres: 10
ewres: 10
rows: 5527
cols: 5007
cells: 27673689
Rich
river...)
Daniel,
   Perhaps if I explain what I'm trying to do it will help everyone who's
assisting me.
   There's a small parcel of land several hundred meters below a dam. On
January 1, 2009, after almost 14 inches of rain in the past week (including
6.44 inches the day before), that property flooded, including the trailer
house sitting there. This is the first flat spot below the dam (and the dam
spillway operated properly); the creek is deeply incised with almost
vertical walls below the dam. The bank on the other side from the property
is higher so all the flooding was all on this one side. Of course, lower in
the drainage basin flooding was more extensive (including a brand-new house
that hasn't sold in two years because it was built on the floodplain.)
   What I want to show is where all that precipitation runoff came from, and
that it's not all from the reservoir overflowing the spillway. Immediately
west of the flooded property is a steep hill, so a lot of surface runoff
came from there and augmented what was transported in the stream channel.
Well, put your pour point on top of the accumulation map and see if it's
on top of the river. If not, change your easting and northing coordinates
appropriately. If you come from ArcGIS world, they have a tool called Snap
Pour Point that does that. I recall doing something similar in grass using
   The last time I used ARC/Info was 1989. :slight_smile:
   The pour point is on the stream channel. See the attached .png that I
forgot to put on my response to Stephen. The topmost 'x' is the flooded
property, the one below it is the center of the dam.
Rich
(attachments)
Looking at the PNG it does not look like any of the pour points are on
the channel. It has to be exactly on top of the lines in the flowacc
map. By setting the pour point to the right place you can delineate
the drainage area for each of them and see how much came from the
reservoir.
On Wed, Feb 10, 2010 at 5:47 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
river...)
Daniel,
assisting me.
Rich
agreed- the lower point does not look like it is on the stream.
On Wed, Feb 10, 2010 at 1:56 PM, Daniel Victoria
reservoir.
river...)
Daniel,
assisting me.
Rich
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
                -K. Mullis
Looking at the PNG it does not look like any of the pour points are on the
channel. It has to be exactly on top of the lines in the flowacc map. By
setting the pour point to the right place you can delineate the drainage
area for each of them and see how much came from the reservoir.
Daniel,
   OK. I'll read the exact point adjacent to the x's and re-run the analysis.
   I'm reading the TNT tutorial now and will then get back to GRASS. ESRI
docs after that.
Rich
The easiest way that I have found to snap a point to a stream is to
use Qgis to edit the vector.
hth,
Stephen
On Wed, Feb 10, 2010 at 2:04 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Daniel,
docs after that.
Rich
Stephen Sefick
                -K. Mullis
Micha,
The r.water.outlet module takes two parameters: first is the drainage *direction* raster, which I usually create first with r.watershed, like:
>r.watershed elev=dem drain=flow_dir accum=flow_acc basin=basin stream=str thresh=xxxx
(At this stage you can go and make popcorn...)
Next I do r.thin on the streams raster, and convert the thinned raster to a line vector:
>r.thin str out=str_thin
>r.to.vect -s str_thin out=streams feature=line
Now you need the pour point which, as others have made abundantly clear ( :wink: ), must be exactly on a stream line. So zoom in *very* close to the flooded house, and identify the X-Y coords on the stream just below the house.
Now try:
>r.water.outlet drain=flow_dir basin=house_catchment east=xxx north=yyy
And finally the above trick to get your final vector drainage basin with:
>r.null house_catchment setnull=0
and
>r.to.vect -s house_catchment out=house_catchment feature=area
Good luck...
zone: 0
datum: nad83
ellipsoid: grs80
north: 1334420
south: 1279150
west: 769190
east: 819260
nsres: 10
ewres: 10
rows: 5527
cols: 5007
cells: 27673689
Rich
Micha Silver
http://surfaces.co.il
and
Micha,
   I have the coordinates correct now. When I get the house_catchment map I
want the area encluded. Haven't found how to calculate that; v.build?
Rich
Rich Shepard pisze:
and
Micha,
Rich
try to use r.stram.basins from add ons it has solevd thsese prooblems
   Ah! Will do. Thanks, Jarek.
Rich
Rich Shepard pisze:
Rich
see it before:
http://grass.osgeo.org/wiki/R.stream.*
in general tutorial is out of date, (you do not need to patch dir map now), there are much more posibilites than there
Jarek,
   Will r.stream.stats calculate the basin area for the two sub-catchments?
I see the input parameters as the raster maps for streams, flow direction,
and DEM. Doesn't seem to calculate the areas of the two vector polygons.
Rich
Micha,
   This process worked flawlessly ... once I corrected slightly off
coordinates for the dam point. The last step I need is a way to calculate
the areas of these two partial basins. They have no attribute information
other than a category number.
   I tried v.overlay (intersecting the two maps) thinking that would
calculate the area of the smaller (b) map from that of the larger (a) map.
Doesn't work that way.
   My next try is to set the region to each of these partial basins,
one-by-one, then calculate the area by multiplying the number of cells by
100 (10x10m resolution) and converting that to acres. This does not seem
sufficiently precise to calculate the difference in drainage areas.
   r.stream.stats does not appear to help because that's working on the
raster maps and not the vector versions.
   Isn't there a way to calculate areas of the vectors produced by the
r.water.outlet-to-vector process?
Rich
   Of course there is, silly me: v.report. Works like a charm.
Rich
Micha,
How about:
> v.db.addcol house_basin col="area_sqm DOUBLE PRECISION"
>v.to.db house_basin opt=area col=area_sqm units=meters
Rich
Micha Silver
Rich Shepard pisze:
Jarek,
Rich
every cachmenet you can calculate using v.to.db what=area for polygons
