I deleted a mapset in one location and now when I invoke grass7x it
shows an error because the mapset is not found. Does something need to be
cleaned up by hand?
TIA,
Rich
cleaned up by hand?
TIA,
Rich
Hei Rich,
If I am not mistaken, the last used mapset is stored in $HOME/.grass7/rc which is picked up by GRASS if you start it in text mode.
However, you can of course explicitly specify the mapset to use at startup using:
grass72 /mygrassdb/mylocation/mymapset -text
See also: https://grass.osgeo.org/grass72/manuals/grass7.html
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Rich Shepard
Sent: 16. september 2016 22:55
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] Deleted mapset; grass error on start
I deleted a mapset in one location and now when I invoke grass7x it shows an error because the mapset is not found. Does something need to be cleaned up by hand?
TIA,
Rich
grass-user mailing list
Stefan,
I thought it was stored somewhere but did not look for the rc file.
using: grass72 /mygrassdb/mylocation/mymapset-text
True. But I want to create a new location so this doesn't help.
Rich
No, but
grass72 /mygrassdb/my_new_location/my_new_mapset -text -c EPSG:myepsg
should help. More details in the manual...
Stefan
Sent: 16. september 2016 23:49
Subject: Re: [GRASS-user] Deleted mapset; grass error on start
Stefan,
startup
Rich
No, but grass72 /mygrassdb/my_new_location/my_new_mapset -text -c
EPSG:myepsg should help. More details in the manual...
Stefan,
I found a web site that lists all the equivalent codes. Posted the URL to
the maillist.
Rich
