Hello !
I would like to delete temporary files during the process of a python script. I have look at g.tempfile but it seems I don’t know how to use it in a python script.
I have tried :
PROCESS_ID = os.getpid()
TEMP1 = grass.read_command (‘g.tempfile’,
pid = PROCESS_ID)
But this changes nothing, after about 67200 calculations of r.viewshed no more temporary file can be created and the script stopped.
It seems to me that i miss something… If anyone knows how to solve that ?
Thanks for your help
yann
Yann Le Jeune
Web : http://www.paleosystem.fr https://ello.co/yannz
On Sun, Jun 2, 2019 at 11:00 AM Micha Silver <tsvibar@gmail.com> wrote:
On 6/1/19 4:43 PM, Le Jeune Yann wrote:
Hello !
I would like to delete temporary files during the process of a python script. I have look at g.tempfile but it seems I don't know how to use it in a python script.
I have tried :
TEMP1 = grass.read_command ('g.tempfile',
pid = PROCESS_ID)
Are you manually removing the TEMP1 files within your script? I think that GRASS cleans up tempfiles only when the session exits, so with such a large number of calculations, you should manually remove them within the script.
For an example, see
scripts/r.in.aster/r.in.aster.py
therein, this function is used:
grass.try_remove(tempfile)
Thanks to you both !
I think that’s what i was missing…
It works now !
yann
Yann Le Jeune
