On Mon, May 18, 2015 at 4:47 PM, Irantzu Alvarez <irantzu.alvarez@gmail.com> wrote:
I am trying to create a DEM from a bathymetric contour lines.
To replicate, I have downloaded a bathymetric DEM portion from
http://www.marine-geo.org/tools/maps_grids.php
(downloaded as GeoTIFF, LatLong, imported with r.in.gdal).
I am using GRASS GIS 7.0.svn here.
Contours are
in vector format and the elevation value is negative (integers).
ok, in my test case I have run
r.contour GMRTv2_7_bathy_mediterranean step=100 min=-4000 max=3500 output=GMRTv2_7_bathy_mediterranean_contours_100m
To create
the surface I have converted the contours in raster (v.to rast)
Yes:
v.to.rast input=GMRTv2_7_bathy_mediterranean_contours_100m output=GMRTv2_7_bathy_mediterranean_contours_100m use=attr attribute_column=level
and then I
have used r.surf.contour, but It doesn’t work (there is no error but the
resulting output raster is exactly the same as the previous one, without any
interpolation).
Strange. Here, with
r.surf.contour input=GMRTv2_7_bathy_mediterranean_contours_100m output=GMRTv2_7_bathy_mediterranean_interpol
… I got back a nice bathymetric DEM (naturally, the “differences” map generated with r.mapcalc shows some differences to the original map I derived the contour lines from given the oversimplification done with the vectorization).
This are my region settings:
g.region -p -a raster=contours@iiaa nsres=1 ewres=1
projection: 1 (UTM)
zone: 30
rows: 27443
cols: 114763
cells: 3149441009
Which GRASS GIS version are you using?
I need a DEM of very high resolution of a wide area. I am using a computer
with large capacities for it.
Yes, but which operating system?
My full procedure below.
HTH,
http://consulting.neteler.org
http://courses.neteler.org/next-training/
http://gis.cri.fmach.it/neteler/
######## Test case procedure (GRASS GIS 7)
r.in.gdal /home/neteler/data/GMRTv2_7_20150525topo.tif out=GMRTv2_7_bathy_mediterranean -o
g.region raster=GMRTv2_7_bathy_mediterranean
r.colors GMRTv2_7_bathy_mediterranean color=srtm_plus
visualize imported map
d.mon wx0
d.rast GMRTv2_7_bathy_mediterranean
generate contour lines (for our test case)
r.info GMRTv2_7_bathy_mediterranean
d.vect GMRTv2_7_bathy_mediterranean_contours_100m
rasterize contour lines
visualize colorized contour lines
d.mon wx1
r.colors GMRTv2_7_bathy_mediterranean_contours_100m color=srtm_plus
d.rast GMRTv2_7_bathy_mediterranean_contours_100m
interpolate DEM from contour lines
r.colors GMRTv2_7_bathy_mediterranean_interpol color=srtm_plus
r.info GMRTv2_7_bathy_mediterranean_interpol
visualize new resulting map
d.mon wx2
d.rast GMRTv2_7_bathy_mediterranean_interpol
generate differences map for validation
r.mapcalc “GMRTv2_7_bathy_mediterranean_diff = GMRTv2_7_bathy_mediterranean - GMRTv2_7_bathy_mediterranean_interpol”
r.colors GMRTv2_7_bathy_mediterranean_diff color=differences
visualize differences map
d.mon wx3
d.rast GMRTv2_7_bathy_mediterranean_diff
optionally generate histogram or profiles via wxGUI
