[GRASS-user] Density of points in a vector layer
See v.kernel
Dylan
On Wed, Jun 10, 2009 at 7:42 AM, Paolo Tome<paolo_tome@hotmail.com> wrote:
Hello,
I'm using grass in combination with qgis; I would know how can I
calculate the density of points in a vector layer. In the past I used
gvsig and Sextante, in particular I used "density kernel" tool. Which
equivalent application can I use in Grass?
Thank you for any useful advice!
Paolo Tomè
grass-user mailing list
grass-user@lists.osgeo.org
On Wed, Jun 10, 2009 at 8:27 AM, Paolo Tome<paolo_tome@hotmail.com> wrote:
Thanks for your reply, I tried to use v.kernel but the result is not
very satisfactory (a raster uniformly colored of gray), I don't have
much familiarity with the console, then I use the graphical interface of
the application (using QGIS) . Then I can set only the "maps in
Stdeviation units" (parameter which I did not understand the full
meaning). Can you give me some guidance on how to obtain a better
result? Thank you very much.
Hi Paolo,
The command line is the most flexible approach to using GRASS. When
using modules that generate raster output you need to consider the
region resolution and extent. Have a look at the raster intro
(http://grass.itc.it/grass64/manuals/html64_user/rasterintro.html).
You will need to work out a resolution that makes sense, then set it
with g.region. Finally, you will have to tinker around with the stddev
option to v.kernel for results that look right to you. Think of this
parameter as the diameter of the 'filter' in which point densities are
calculated. The size of this parameter will be a function of your
dataset and the region parameters.
This module could use an updated manual page, as its usage is somewhat
mysterious.
Dylan
On mer, 2009-06-10 at 08:18 -0700, Dylan Beaudette wrote:
See v.kernel
Dylan
> Hello,
> Paolo Tomè
