-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Hamish, Ahmadou,
Hamish: The file VERSIONNUMBER is exactly what I was looking for - thanks.
Ahmadou:
On 13/09/11 02:12, ahmadou dicko wrote:
The way Rainer use R for scripting GRASS don't allow him to use
the GRASS_VERSION variable, so i think the only way is to use the
second solution proposed by Hamish.
Exactly.
something like that should do the trick in R
readLines(paste(Sys.getenv("GISBASE"), "etc", "VERSIONNUMBER", sep
Perfect.
But if you launch R from GRASS or set some GRASS variable
permanently you can simply do
Sys.getenv("GRASS_VERSION")
Terue - but as you pointed out, I am not running R from within GRASS,
so the file VERSIONNUMBER is the way to go.
Thanks a lot,
Rainer
2011/9/12 Hamish <hamish_b@yahoo.com <mailto:hamish_b@yahoo.com>>
Rainer wrote:
I am using GRASS from within an R script, and would need the
GRASS version. I do not know the startup script, so grass
--version is not an option. Nevertheless, I have obviously
specified the GRASS directory where the grass executables and
scripts sit. Is there one which I can use to get the grass
version?
If grass is started you can use the GRASS_VERSION enviro variable
or the g.version module to get it.
If GRASS is not started you can look in the
$GISBASE/etc/VERSIONNUMER file.
Hamish
_______________________________________________ grass-user mailing
list grass-user@lists.osgeo.org
<mailto:grass-user@lists.osgeo.org>
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk5vAFQACgkQoYgNqgF2egpSnwCfUZrg930ykKYaV97DCQV5hSx8
+SEAoIReUpAZOJ3B5M1WS7t3NoZ8xYga
=7s38
-----END PGP SIGNATURE-----
