greetings,
i am is in a confusion after going to some pages. http://grass.itc.it/grass60/index.php, on this page, saysi can do import export of vector data such in format shape, postgis, GML2, " DGN". If i go to http://www.gdal.org/ogr/ogr_formats.html says neither georefrening nor creation is supported.Also on previous list,it say DGN format is not open. Again i found some images (not maps in dgn from web) and able to open it but i don’t know how much correct it is.
greetings,
i am is in a confusion after going to some pages. http://grass.itc.it/grass60/index.php, on this page, saysi can do import export of vector data such in format shape, postgis, GML2, " DGN". If i go to http://www.gdal.org/ogr/ogr_formats.html says neither georefrening nor creation is supported.Also on previous list,it say DGN format is not open. Again i found some images (not maps in dgn from web) and able to open it but i don't know how much correct it is.
Grass Choper,
The ogr_formats.html document was wrong ... creation of DGN files *is*
supported with OGR. The lack of georeferencing really just means that
spatial reference systems are not supported for DGN. That means you can't
find out the coordinate system from the file itself.
There are various limitations to DGN support, including that it only applies
to pre-DGNv8 files.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
