This will not be a specific GRASS question. My friend and I tried to calculate NDVIs of same data set and results seem same to us. But checking statistics of each output we saw that statistics are very different. I mean, median, mean, std.dev values of Grass output and Erdas output are different. We couldn’t find an explanation for this situation. What can be the reason for this?
PS:
For NDVI, we used this formula: (NIR_Band - RED_Band) / (NIR_Band + RED_Band)
Hi, Please make sure that the output images are of the same type in both cases and that your statistic calculation method is the same. NDVI is a float (or double) result if your initial data are integers (usually they are). Perhaps one of your images is automatically converted to 8 bit integer type? Cheers, Angelos
On 01/14/2013 01:03 AM, Gökçen Güner wrote:
different. We couldn't find an explanation for this situation. What can be
PS:
RED_Band)
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
[http://users.ntua.gr/tzotsos](http://users.ntua.gr/tzotsos)
We did both statistics calculation using QGis because ERDAS couldn’t calculate statistics for Grass output (or we couldn’t do it). I’m sure that Grass output is floating point map but I’ll check Erdas one.
Thanks
PS:
RED_Band)
Angelos
Angelos Tzotsos
On Monday 14 of January 2013 01:03:42 Gökçen Güner wrote:
Hi!
different.
How different? Can you please post exact numbers if that is ok? If differences
are minor, you can simply ignore them
There are reasons. For example, different pixel inclusion rules (of course I
have in mind border-near pixels). Other reasons might be the spatial
resolution and extent (remember, GRASS-GIS is strict with that) and the
presence of a MASK.
The experts might give better clues.
Best, Nikos
PS:
RED_Band)
What kind of images are those, if I may ask? Which sensor?
presence of a MASK.
Also,
what about NULL or NoData cells? How does ERDAS deal with them -- I don't
remember now. How are they defined, if they exist, in your image?
What does "r.describe -r" return for the data set(s) in question?
Thank you for reply. I don’t have exact NDVI band statistics but I have statistics of NDVI difference maps. We calculated NDVI’s of different times for same area and then subtract one from another. I mean we have NDVI of 2000 and 2010 for the same area and we subtracted NDVI 2000 from NDVI 2010. I can send statistics of original NDVI files tomorrow. These are statistics of difference maps. I attached them to my post.
I’m not sure about ‘different pixel inclusion rules’ but I think ‘spatial resolution and extent’ is same for both, you can see it in stat files I sent. Also we didn’t use MASK in both.
Thanks.
Hi!
different.
presence of a MASK.
Best, Nikos
PS:
RED_Band)
presence of a MASK.
Also,
what about NULL or NoData cells? How does ERDAS deal with them – I don’t
What does “r.describe -r” return for the data set(s) in question?
Hi, @Nikos:
I’ll send information about maps tonight. I’ll send ‘r.describe -r’ output also. @Sylvain:
Thank you, I didn’t noticed the differences, my friend might had done histogram strecthing over results, so this may be the reason for -2/2 thing, I will check this.
By the way I’m not sure how we can make data to have same layer extent and dimension in both programs. I didn’t do a special thing before calculation, I just used g.region and
r.mapcalc methods.
presence of a MASK.
Also,
@Nikos: I'll send information about maps tonight. I'll send 'r.describe -r'
output also.
I think it might not be necessary. As Sylvain pointed-out, and I confirm this
(had a quick look in the morning), the reported layere dimensions are
different! Check it out please.
This might be the single root of evil in this case.
@Sylvain: Thank you, I didn't noticed the differences, my friend might had
By the way I'm not sure how we can make data to have same layer extent and
dimension in both programs. I didn't do a special thing before calculation,
I just used g.region and r.mapcalc methods.
Hi Nikos,
Yes I didn’t noticed the differences until Sylvain said, too
I did g.region you are right, I did it to the imported maps, I wrote it in my last post. What i don’t know is how to do same thing in Erdas but this is grass mailing list so my friend will ask about this in erdas forums.
