Greetings
I have a script that runs automatically r.composite but when i compare my RGB with an RGB (using the same images) bur produced with r.composite outside my script I get the same image but with a different aspect (it doesnt seem to be real color). Do i need to apply a color table to my RGB produced from r.composite?
here goes the Metadata
The one with error
r.info map=2008_RGB_MSC08@Mountain
| Layer: 2008_RGB_MSC08@Mountain Date: Fri Apr 15 09:39:12 2011 |
| Mapset: Mountain Login of Creator: LL |
| DataBase: D:\data\ |
| Title: ( 2008_RGB_MSC08 ) |
Timestamp: none |
Type of Map: raster Number of Categories: 32767 |
Data Type: CELL |
Rows: 4653 |
Columns: 4519 |
Total Cells: 21026907 |
Projection: UTM (zone -24) |
N: 9059487.76299512 S: 9040875.76299512 Res: 4 |
E: 576932.87815394 W: 558856.87815394 Res: 4 |
Range of data: min = 31 max = 32767 |
Data Description: |
generated by r.composite |
Comments: |
r.composite red=“2008_bandR_MSC08” green=“2008_bandG_MSC08” blue="20\ |
08_bandB_MSC08" levels=32 output=“2008_RGB_MSC08” |
The one that is OK (not produced in script)
r.info map=ai@Mountain
| Layer: ai@Mountain Date: Tue May 17 02:11:55 2011 |
| Title: ( ai ) |
Timestamp: none |
Data Type: CELL |
Rows: 4653 |
Columns: 4519 |
Range of data: min = 0 max = 32767 |
Data Description: |
Comments: |
| r.composite red=“2008_bandR_MSC08@Mountain” green=“2008_bandG_MSC08@Mou\ |
| ntain” blue=“2008_bandB_MSC08@Mountain” levels=32 output=“ai” |
Thanks
Luisa
