[GRASS-user] Different coordinate system maps
Hallo
I would like to know if is there any way to load into a workspace maps that are in a different coordinate system than the mapset you are working in. In my case, I have a location using UTM zone 29 and I need to display some maps georefered in UTM zone 30. Is there any possibility?
Thanks for any help.
Carlos Dávila
possibility?
Use r.proj and v.proj to pull in maps from another location with
different projection settings.
Be aware that the further you go out into the bordering UTM zones, the
more distortion you'll see.
Hamish
