[GRASS-user] Different distances to outlet for r.stream.order and r.stream.distance
Dear List
r.stream.order gives, among other output, the distance of current the stream init from the outlet of the catchment ('out_dist'). So for the most downstream segment this is identical to the length of the segment. r.stream.distance calculates the distance to the outlet and results in a raster file. Both are based on a stream raster and a direction raster.
When I compare the results, they are slightly different, although based on the same input files (see the attached Fig1). The raster value is 212.33 at the junction, while the out_dist of the line is 237.69. The difference is one cellsize (25.023 in may example), probably due to the horizontal bit of the line at the end (upper right of the figure). However, this difference is not fixed. In the middle of the network (Fig2) it is larger (81028.9 - 81002.89 = 27).
What is the reason for this difference? Is this a bug or a wanted behaviour?
I want to extract the position of points on the network (i.e. upstream of a junction on the lines). To this end, I planned to use the upstream distance of the points and the out_dist of the segments (length(segment) - (out_dist(segment) - upDist(point)) = position(point)).
Has anybody another idea how to accomplish this?
Thanks a lot,
Mira
(attachments)
On Tue, Sep 20, 2016 at 10:53 AM, Mira Kattwinkel
<kattwinkel-mira@uni-landau.de> wrote:
Dear List
Yes, this horizontal bit of the line is a bug in r.stream.order, the
stream vector is leaving the current region or going into a NULL cell.
All other r.stream.* modules place the outlet on a valid cell. Fixed
in r69542.
81002.89 = 27).
What is the difference in the middle of the network now with r69542?
Markus M
Thanks a lot,
Mira
grass-user mailing list
grass-user@lists.osgeo.org
Thanks a lot!
I saw that you uploaded a revision. Can you please give me a hint how I upgrade to the revised version of r.stream.order? I am running Linux Mint 17.3 and Windows 7.
I found that there are nightly pre-built Addon executables for Windows, so I will try that tomorrow. What about Linux? Is it sufficient to just reinstall the addon?
All the best,
Mira
Am 21.09.2016 um 11:08 schrieb Markus Metz:
Dear List
in r69542.
81002.89 = 27).
Markus M
Thanks a lot,
Mira
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Fon: + 49 6341 280-31553
I found that there are nightly pre-built Addon executables for >Windows,
Yes, for Linux it's enough to reinstall. For Windows you have to wait for
the next daily build.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Different-distances-to-outlet-for-r-stream-order-and-r-stream-distance-tp5286849p5287085.html
On Wed, Sep 21, 2016 at 1:26 PM, Mira Kattwinkel
Thanks a lot!
17.3 and Windows 7.
I have fixed another bug in r.stream.order (r69543): the stream
segment lengths are now identical to the lengths of the vector lines
and the out_dist value of r.stream.order matches now the output of
r.stream.distance. BTW, any reason why the resolution is 25.023 and
not exactly 25?
Markus M
the addon?
All the best,
Mira
Dear List
stream
on
at
of
in r69542.
81002.89 = 27).
Markus M
behaviour?
a
distance
Thanks a lot,
Mira
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
Dear Markus, dear List
It is much better now but still not exactly the same. Close to the outlet, the difference in distance to the outlet is about 30 cm (Fig_1b) and in the middle of the network it’s about 80 cm (Fig_2b). The upDist raster produced with r.stream.distance gives the exact length I would expect (for Fig_1b: 6 * sqrt(2 * 25.0235 ^2) = 212.33) while r.stream.order still results in slightly to high values. .
That’s good enough for the task I am working on but I wonder why this is the case.
Btw, I checked and my dem really has a cell size of 25.0235. I do not know why this is the case.
Mira
(attachments)
[<kattwinkel-mira@uni-landau.de>](mailto:kattwinkel-mira@uni-landau.de) wrote:
Thanks a lot!
17.3 and Windows 7.
not exactly 25?
Markus M
the addon?
All the best,
Mira
Dear List
stream
on
at
of
in r69542.
81002.89 = 27).
Markus M
behaviour?
a
distance
Thanks a lot,
Mira
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
On Thu, Sep 22, 2016 at 4:17 PM, Mira Kattwinkel
middle of the network it's about 80 cm (Fig_2b). The upDist raster produced
That's good enough for the task I am working on but I wonder why this is the
case.
r.stream.order used single precision floating point values for easting
and northing while r.stream.distance uses double precision. This can
make a difference when calculating distances. I changed r.stream.order
with r69566 to also use double precision for distance calculations.
Can you please test after reinstalling r.stream.order? Thanks!
Such odd numbers typically occur when raster data are reprojected with
default settings and can cause various problems (calculating extents,
distance calculations, exact export to other data formats etc). The
default settings for reprojection, e.g with r.proj -g or gdalwarp,
will produce some output (in the past I have received DEMs with
strange reprojection settings from someone else in your group), but it
is worth to fine-tune the output grid geometry (extents and
resolution) and select an appropriate resampling method which in turn
depends on the kind of input data and the desired output resolution.
Markus M
Mira
Thanks a lot!
17.3 and Windows 7.
not exactly 25?
Markus M
the addon?
All the best,
Mira
Dear List
stream
on
at
of
in r69542.
81002.89 = 27).
Markus M
behaviour?
a
distance
Thanks a lot,
Mira
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
case.
Yes, now the distances are exactly the same everywhere in the network.
Thank you!
Mira
Markus M
Mira
Thanks a lot!
17.3 and Windows 7.
not exactly 25?
Markus M
the addon?
All the best,
Mira
Dear List
stream
on
at
of
in r69542.
81002.89 = 27).
Markus M
behaviour?
a
distance
Thanks a lot,
Mira
