when I try to digitize a vector map, a different "digitize menus" are not created.
I tried to have it on both "debian GRASS 6.0.2 " and "compiled GRASS 6.0.2". But
nothing happened. Older versions used to provide it.
what can I do ?
regards
Ahmet Temiz
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
not created.
6.0.2". But nothing happened. Older versions used to provide it.
does it work if at the GRASS console prompt you do:
not created.
not created.
I tried to have it on both "debian GRASS 6.0.2 " and "compiled GRASS 6.0.2". But nothing happened. Older versions used to provide it.
d.mon x0
v.digit
if not, what sort of error do you see?
Hamish
thank you
when I enter:
- d.mon x0
- v.digit -n map=sil4 bgcmd="d.rast map=asp1"
GRASS replies:
"Map does not exist.
New empty map created.
100%
Segmentation fault"
and maybe because of Segmentation fault "digitize menu " never appears.
regards
Ahmet Temiz
not created.
d.mon x0
v.digit
Hamish
thank you
when I enter:
- d.mon x0
GRASS replies:
100%
Segmentation fault"
