Dear GRASS-users,
I need to modify an existing polygon-theme in GRASS/QGIS: some areas have to be changed in size. Within the digitize-module of QGIS, I used the tool "Move element" and "Add new boundary". However, I was not able to close the polygon again (it is still drawn in red, not in green). Therefore, I would be very glad for some general hints about digitizing in GRASS!
Best,
Wolfgang
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Hi Wolfgang -
I have recently used v.digit for the first time (in Grass 6.0.1).
I had similar problems. Changing the snapping threshold did not work for me. I just had to zoom in close enough instead.
I then switched to digitising with the Grass plugin of Qgis, because there I could zoom with the mouse wheel during vertex input.
-- Robert
Dear GRASS-users, I need to modify an existing polygon-theme in
Do you mean v.digit?
In QGIS such operations (if I correctly understand what you mean) work
OK for me.
Maciek
