Hi Paulo,
thanks for the hint!
Now I have some trouble to install the addon:
As a standard user I am not allowed to create a directory under /usr/lib.
A second try as root failed because HTML2MAN within “Grass.make” tries to
call
$(GISBASE)/tools/g.html2man.py. But the python script is called
g.html2man.
After linking g.html2man.py to g.html2man the built of the addon fails
because
of a missing python module (ImportError: No module named html).
This was on ubuntu 14.04 with grass70 from the ppa:grass-devel.
Version 7.0.0+1svn64464~ubuntu14.04.1 installed today.
Are addons supposed to be installed by standard users?
thanks
robert
as standard user:
GRASS 7.0.0 (wgs84):~ > g.extension extension=r.grow.shrink
svnurl=http://svn.osgeo.org/grass/grass-addons/grass7 --verbose
Fetching <r.grow.shrink> from GRASS-Addons SVN repository (be patient)…
A r.grow.shrink/DEPRECATED
A r.grow.shrink/main.c
A r.grow.shrink/Makefile
A r.grow.shrink/r.grow.shrink.html
U r.grow.shrink
Checked out revision 64471.
Compiling…
mkdir -p /tmp/tmpGP17FI/r.grow.shrink/bin
mkdir -p /tmp/tmpGP17FI/r.grow.shrink/etc
mkdir -p /tmp/tmpGP17FI/r.grow.shrink/docs/html
mkdir -p /usr/lib/grass70/docs/man
mkdir: cannot create directory ‘/usr/lib/grass70/docs/man’: Permission
denied
make: *** [/usr/lib/grass70/docs/man] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
as root (sudo -i):
U r.grow.shrink
Compiling…
mkdir -p /tmp/tmpa27tYO/r.grow.shrink/bin
mkdir -p /tmp/tmpa27tYO/r.grow.shrink/etc
mkdir -p /tmp/tmpa27tYO/r.grow.shrink/docs/html
mkdir -p /tmp/tmpa27tYO/r.grow.shrink/docs/man/man1
test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
gcc -Wall -g -O -I/usr/lib/grass70/include -I/usr/lib/grass70/include
DPACKAGE="“grassmods”" -I/usr/lib/grass70/include -
I/usr/lib/grass70/include -DRELDIR="/tmp/tmpa27tYO/r.grow.shrink" -o
OBJ.x86_64-pc-linux-gnu/main.o -c main.c
: && gcc -L/usr/lib/grass70/lib -L/usr/lib/grass70/lib
-Wl,–export-dynamic -
Wl,-rpath-link,/usr/lib/grass70/lib -o
/tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink
-lgrass_gis.7.0.0svn -lgrass_raster.7.0.0svn -lm
if [ “/tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink” != “” ] ; then
GISRC=/tmp/grass7-root-12200/gisrc GISBASE=/usr/lib/grass70
PATH=“/usr/lib/grass70/bin:/usr/lib/grass70/bin:/usr/lib/grass70/scripts:
$PATH”
PYTHONPATH=“/usr/lib/grass70/etc/python:/usr/lib/grass70/gui/wxpython:
$PYTHONPATH”
LD_LIBRARY_PATH=“/tmp/tmpa27tYO/r.grow.shrink/bin:/usr/lib/grass70/scripts
:/usr/lib/grass70/lib:/usr/lib/grass70/lib:/usr/lib/grass70/lib” LC_ALL=C
/tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink --html-description <
/dev/null | grep -v ‘|’ > r.grow.shrink.tmp.html ; fi
VERSION_NUMBER=7.0.0svn VERSION_DATE=2015 \
python /usr/lib/grass70/tools/mkhtml.py r.grow.shrink >
/tmp/tmpa27tYO/r.grow.shrink/docs/html/r.grow.shrink.html
VERSION_NUMBER=7.0.0svn /usr/lib/grass70/tools/g.html2man.py
/tmp/tmpa27tYO/r.grow.shrink/docs/man/man1/r.grow.shrink.1
/bin/sh: 1: /usr/lib/grass70/tools/g.html2man.py: not found
make: *** [/tmp/tmpa27tYO/r.grow.shrink/docs/man/man1/r.grow.shrink.1]
Error
127
rm r.grow.shrink.tmp.html
Am Donnerstag, 5. Februar 2015, 14:53:05 schrieb Paulo van Breugel:
Check out the r.growth.shrink addon.
On Thu, Feb 5, 2015 at 1:59 PM, Robert Nuske <rnuske@gwdg.de> wrote:
Hi there,
looking at some noisy raster map, I would like to clean up the patches
(map
consists only of one class and NULL) using basic mathematical
morphology
(dilation & erosion) in GRASS 7.0.
The dilation can easily be achieved with r.grow.
But the erosion seems not to be as straight forward.
Since the example about shrinking was removed from the help page of
r.grow
in
GRASS 7.0 (http://grass.osgeo.org/grass70/manuals/r.grow.html), I
hoped
for an
easier way to carry out the erosion. Looking in vain for a raster
command
named shrink or erode, I tried a negative distance in r.buffer (->
error)
and
negative radius in r.grow (treated as absolute value).
The following produce identical output with grown patches.
r.grow in=mod_10_33 out=mod_10_33_1 radius=1.1
r.grow in=mod_10_33 out=mod_10_33_2 radius=-1.1
Any suggestions for a quick erosion?
thanks
Robert
grass-user mailing list
grass-user@lists.osgeo.org
