Colleagues,
Finally, after probably a year I now have no errors about incompatible versions of wxwidgets, wxpython, and GRASS. However, when I execute
d.mon wx0
it pops up the box, but which then spontaneously disappears after about 10-15 seconds. It leaves behind the MONITORS/wx0 file. Honestly I'm pretty much at my wits end with wxwidgets.
I run manjaro(arch) linux with the the custom build by Sylvain Poulain at
https://github.com/giscan/AUR-grass
uname -a
Linux sonnyboy 5.4.116-1-MANJARO #1 SMP PREEMPT Sun May 2 11:10:35 UTC 2021 x86_64 GNU/Linux
Thanks in advance for any help, Dave
David W. Roberts office 406-994-5670
Professor FAX 406-994-3190
Department of Ecology email droberts@montana.edu
117 AJM Johnson Hall
Montana State University
Bozeman, MT 59717-3460
On 12/05/2021 13:30, Dave Roberts wrote:
Colleagues,
Finally, after probably a year I now have no errors about incompatible versions of wxwidgets, wxpython, and GRASS\. However, when I execute
d.mon wx0
uname -a
Same here:
- Arch Linux
- grass 7.8.5
- GTK 3.24.29
- wxGTK2/3 3.0.5
- system Python 3.9.4
After a 'd.mon start=wxN', the monitor comes
up, I can use 'd.*' commands to draw into it.
I can resize and move the window, and I can
interact with the UI elements in the icon and
status bars. However: When I move the mouse
cursor inside the monitor's map canvas, d.mon
crashes and closes its window (after a delay
of a few seconds).
I can then use 'd.mon stop=wxN' and start
the monitor again, with the same behaviour
as above.
Best,
Ben
> Colleagues,
> I execute
> d.mon wx0
> uname -a
Same here:
- Arch Linux
- grass 7.8.5
- GTK 3.24.29
- wxGTK2/3 3.0.5
of a few seconds).
as above.
I was able to reproduce this problem in a fresh Manjaro installation
in Virtualbox.
I have created a new bug report:
https://github.com/OSGeo/grass/issues/1576
Now someone with gdb and child process debugging skills is needed to
get a proper backtrace.
best,
Dave, Ben,
Thanks to Anna and Tomas I now remember that the same happened in
Fedora as well (last year).
It seems that Arch/Manjaro are still missing this upstream fix for
wxPseudoDC.FindObjects crash:
https://github.com/wxWidgets/Phoenix/pull/1849
(in Fedora, it had been backported in
https://src.fedoraproject.org/rpms/python-wxpython4/c/f5471fb86aaae46a686b85c654fcbb98516355e6?branch=rawhide)
Hence it is not directly a GRASS GIS problem but has to be fixed in wxWidgets.
Please contact the maintainer of Arch/Manjaro wxWidgets to patch it
accordingly and release an update (such as Fedora has done).
Best,
