[GRASS-user] Display behavior of table attribute data
I learned something surprising this morning using a combination of the GUI
management window's map 'display table attributes' and db.execute.
The two adjacent bathymetric point files imported with a Z-int column with
type double precision for the integer depths. However, the depth values
displayed are in double precision format (ending in .00).
I added a new column, depth_int (type int), and copied (using SQL's 'alter
table') the Z-int double precision values to the depth_int column, then
deleted the Z-int column. The GUI's attribute table management dialog
confirmed that the depth_int is of type integer.
After re-displaying these maps the depth values are still double precision
while the column data type is integer. Oh well.
Rich
That is, I guess, because sqlite 'uses dynamic typing. It does not enforce data type constraints. Data of any type can (usually) be inserted into any column. '?
management window’s map ‘display table attributes’ and db.execute.
I added a new column, depth_int (type int), and copied (using SQL’s ‘alter
table’) the Z-int double precision values to the depth_int column, then
deleted the Z-int column. The GUI’s attribute table management dialog
Rich
grass-user mailing list
grass-user@lists.osgeo.org
column. '?
Paulo,
That's true; sqlite3 stores everything as text and allows the application to
format what's displayed. But, I haven't found a way to present these numbers
as integers in GRASS.
Regardless, I used the annotation tools in the map display window to add a
scalebar and north arrow; couldn't get the text where I wanted with a
transparent background. But when saved, this figure will be adequate for the
project's needs.
Rich
