[GRASS-user] Display output question
On Feb 16, 2009, at 6:34 PM, <grass-user-request@lists.osgeo.org> wrote:
Date: Tue, 17 Feb 2009 10:40:52 +1100
Subject: [GRASS-user] Display output question
To: GRASS user list <grass-user@lists.osgeo.org>
Message-ID: <4999F984.9060605@ozemail.com.au>
Content-Type: text/plain; charset=ISO-8859-1
What's the command-line equivalent to using the JPG export in the
display manager? (I would like to script outputs from a number of
workspace - GRC - files).
Richard
What happens in TclTk is that the display output is set to a PPM file instead of monitor. Then any d.* command creates a graphic file. The display graphic file is then converted to a jpeg. The latter can be done by a variety of programs, including gdal-translate.
In wxPython, the display can be saved in a number of different formats using wxPython drivers.
Michael
Richard
Yes, but AFAIK, you cannot easily use the contents of a .grc or .gxw file for scripting. You would have to parse the file with relevant tools (awk, sed or an xml parser for gxw) and then apply these options to the d.* commands using the cairo or PNG "monitor" to create a PNG file.
In the TclTk GUI, you could save the content of the Output window after having displayed your workspace and filter out the d.* commands. In the wxGUI this is not possible anymore, AFAICT.
It might be worth thinking about a module that translates workspace files into d.* commands...
Moritz
