On Jan 3, 2009, at 6:47 AM, <grass-user-request@lists.osgeo.org> wrote:
Date: Sat, 3 Jan 2009 07:43:17 +0100
Subject: Re: [GRASS-user] Display thematic vector map - WinGRASS 6.3
(Vista)
To: "Ken Brookes" <ken_brookes@hotmail.com>
Cc: Grass GIS Users List WinGRASS User <grass-user@lists.osgeo.org>
Message-ID:
<86782b610901022243o54070b91q3a5802660186b5b0@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On Fri, Jan 2, 2009 at 10:03 PM, Ken Brookes <ken_brookes@hotmail.com> wrote:
Hello
I'm a GRASS GIS novice and have recently downloaded and successfully
installed GRASS 6.3.0 directly onto MS-Windows Vista. I have been playing
with the GIS manager GUI and have run into a problem trying to create
thematic Vector maps and display them in the map display. I am using the
North Carolina data set (example data set provided) and a variety of vector
maps to try and create graduated color, point and line maps to get a feel of
how it works. I have been adding the thematic layer and specifying all the
parameters correctly in the GUI. The actual binning of the numeric data is
occurring properly because a new window will pop-up with the correct
legend for the parameters specified, however nothing will display in the map
display window. I do get a message in the command line shell saying "No such
monitor exists 'PNG' ". I've tried to run d.vect.thematic through the
command line shell and get an error saying "must open display monitor". I'm
not sure what the problem is. Can anyone help?
The problem is that winGRASS does not support X or PNG monitors.
The solution is the new Python based user interface.
I am not sure if there is a d.vect.thematic equivalent already (we are
preparing 6.4.0 these days) which work on Windows since I am no
Windows user.
I hope you get the answer from another group member.
GRASS does support PNG monitors in winGRASS (or the TclTk canvas wouldn't work). There was a bug that caused problems with winGRASS and thematic mapping last Spring. I don't remember what it was, but thought it was fixed. What is the compile date of your version of GRASS 6.3?
I used the WinGRASS 6.3.0-4 Setup.exe to install GRASS on Vista from July 19,
2008.
K. Brookes
(Vista)
Message-ID:
Hello
playing
using the
of vector
a feel of
all the
data is
in the map
"No such
monitor". I'm
Windows user.
GRASS 6.3?
wouldn't work).
WinGRASS supports direct rendering through the PNG and other drivers.
It doesn't support any form of monitor, including PNG. You can't use
d.mon, d.save, d.frame, or d.font.
Thanks for the correction. WinGRASS supports PNG output, not a monitor. d.vect.thematic was rewritten to use direct rendering through PNG, so it should work on Windows.
Michael
______________________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Tempe, AZ 85287-2402
USA
wouldn't work).
This was done in 6.4, so it is not available in winGRASS, yet, which is based on 6.3. Just replacing the script doesn't work, either as it use the fs= parameter of v.db.connect which wasn't introduced until 6.4.
Ken,
You are not alone. I tried the thematic vector example on page 171 of
Neteler & Mitasova and also encountered the "You must open a display
monitor" message. I'm running 6.3.0-4 on Vista.
Matt
On Tue, Jan 6, 2009 at 12:51 PM, Moritz Lennert
I'm pretty sure that this is a Vista issue, though one that has been solved in 6.4.
Michael
On Jan 14, 2009, at 7:33 PM, Matt wrote:
Ken,
Matt
And as the OP is using 6.3, he doesn't have access to that solution, yet. So, we'll have to wait for the version of WinGRASS to decide whether there might be additional issues in Vista.
Moritz
Michael
Ken,
Matt
Probably the d.vector.thematic script can be copied from 6.4 and run in 6.3 with little or no modification.
Michael
USA
Moritz
Michael
Ken,
Matt
As mentioned in the last mail below, you cannot copy it without modifications, as v.db.connect's fs= parameter was introduced in 6.4, and I'm not sure that's the only change.
I think the easiest would probably be to copy the lines setting the relevant environment variables from 6.4 to 6.3 to replace the d.mon call.
Moritz
Michael
USA
Moritz
Michael
Ken,
Matt
