[GRASS-user] displaying lines between given points
A colleague of mine has a data set with airports (and their coordinates) and flights between these airports, i.e. something like this:
x1 y1 x2 y2 flights
He wants to display these connections as lines between the airports, whose line width is proportional to the number of flights.
Anyone have a great idea of how to do this in GRASS ? I currently see the following possibility:
1) use awk to transform the file into an ascii vector line file, i.e.:
L 2 1
x1 y1
x2 y2
1 flights
2) import with v.in.ascii
3) select distinct values from the cats column
4) loop through those distinct values and d.vect with line width set to cats value * scale
Anyone have a better idea ?
Moritz
Alle 11:56, martedì 01 agosto 2006, Moritz Lennert ha scritto:
x1 y1 x2 y2 flights
L 2 1
x1 y1
x2 y2
1 flights
cats value * scale
For line depth you can use the buffer feature...you can set the extension of
the buffer by the number of flight between airport.
Can it works?
Bye
Luca
"Chiunque può simpatizzare col dolore di un amico, ma solo chi ha un animo
nobile riesce a simpatizzare col successo di un amico (Oscar Wilde)"
LINUX User #411601
GENTOO-GIS Development Team
jabber: casagrande@jabber.linux.it
x1 y1 x2 y2 flights
L 2 1
x1 y1
x2 y2
1 flights
cats value * scale
For line depth you can use the buffer feature...you can set the extension of the buffer by the number of flight between airport.
Can it works?
I probably could, but I think working with the 'width' option of d.vect just seems easier.
Moritz
