[GRASS-user] Displaying site_name on r.watershed output basins map
   One output map from r.watersheds is identified basins. I want to use this
output for input to r.basin to calculate descriptors for each one. When I
query the output map I am shown a numeric site_name for each calculated
basin (see attached map with vector streams overlaid).
   Is there a way to display the site_name on each colored basin? This would
make it much easier to communicate basin descriptions by illustrating where
each basin is located in the area. I've looked through the list of r.*
modules and did not find one that would do this task.
Rich
(attachments)
qusa-basins.pdf (62.9 KB)
where each basin is located in the area. I've looked through the list of
r.* modules and did not find one that would do this task.
   Related question: how can I obtain the areas of the calculated basins? I
tried r.to.vect but the output map has no attribute table associated with
it.
Rich
it.
   Answer: r.basin.
Rich
On Tue, May 1, 2012 at 12:17 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
where each basin is located in the area. I’ve looked through the list of
it.
This is weird. Which is the exact command line you used? should be something like:
r.to.vect input=basins output=basins feature=area
Once you have that, you can use v.label to display labels, and calculate the area using v.db.addcol + v.to.db
HTH
madi
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Ing. Margherita Di Leo, Ph.D.
something like:
Madi,
   I used the GUI; will try again with the command line (my preference,
anyway).
   I used a different output name, but did specify area as the feature.
   Didn't do this ... but I will. This is good information for me.
   I also confirmed that r.basin calculates area as part of its output.
Many thanks,
Rich
Rich,
On Tue, May 1, 2012 at 3:47 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
something like:
Madi,
anyway).
Using the GUI, you can check the correspondent command line displayed in the bottom part of the command window.
This doesn’t affect the result at all, it was just for example.
Didn’t do this … but I will. This is good information for me.
Many thanks,
You are welcome
madi
Rich
I mean, the output’s name doesn’t affect the result. The feature=area matters, obviously.
ciao
madi
Once you have that, you can use v.label to display labels.
   I must be doing something incorrectly. After running r.to.vect I ran
v.label specifying 'value' as the attribute column. No labels display even
after I specify the attribute column, color, and size in the GUI dialog. The
command displayed at the bottom of the GUI dialog box reflects the choices
made above.
   What might inhibit the display of the labels?
Rich
v.label specifying ‘value’ as the attribute column. No labels display even
made above.
Have a look that you’ve enabled displaying of an attribute column. In the GUI, it’s on the “Required” tab as “Display selected attribute based on attrcol”. On the CLI "d.vect disp=shape,attr "
This always trips me up also. Should be a FAQ. And perhaps the “Display attribute…” should get enabled somehow automatically whenever an attribute column for labeling is chosen.
Micha Silver
052-3665918
On Wed, 2 May 2012, Micha Silver wrote:
Have a look that you've enabled displaying of an attribute column. In the
GUI, it's on the "Required" tab as "Display selected attribute based on
attrcol". On the CLI "d.vect disp=shape,attr " This always trips me up
also. Should be a FAQ. And perhaps the "Display attribute..." should get
chosen.
Micha,
   I saw that before I wrote for help, but checking the attribute checkbox
makes no difference. I cannot display either the cat numbers nor the
raster map site_name which is the value column in the vector table.
   When I uncheck all features but area the display clears. I have to try
various options before the boundaries re-appear.
   From the command line, writing to d.mon x0:
GRASS 6.5.svn :~/grassdata > d.vect map=basinv disp=shape,attr type=area fcolor=none attrcol=value
produces the attached 'basinv.png'.
   A portion of the attribute table, generated by
GRASS 6.5.svn :~/grassdata > db.select sql="select * from basinv"
is,
cat|value|label
1|8|
3|114|
4|194|
5|190|
6|116|
7|184|
8|198|
9|120|
10|2|
11|192|
12|188|
13|6|
14|188|
15|172|
16|120|
17|4|
18|158|
19|192|
20|192|
21|192|
22|196|
23|118|
24|118|
   I'm not seeing what I've written incorrectly.
Rich
(attachments)
+1
Rich,
On Wed, May 2, 2012 at 3:52 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
attrcol”. On the CLI "d.vect disp=shape,attr " This always trips me up
chosen.
Micha,
what does v.info map=basinv say?
Map scale: 1:1
Map format: native
Name of creator: rshepard
Organization:
Source date: Wed May 2 10:42:33 2012
Type of Map: vector (level: 2)
Number of points: 0 Number of areas: 378
Number of lines: 0 Number of islands: 1
Number of boundaries: 835 Number of faces: 0
Number of centroids: 377 Number of kernels: 0
Map is 3D: No
Number of dblinks: 1
Projection: Transverse Mercator
N: 28704643.97591617 S: 28589696.29729814
E: 628305.08857358 W: 464582.93917488
Digitization threshold: 0
Rich
On Wed, May 2, 2012 at 10:25 PM, Margherita Di Leo <diregola@gmail.com> wrote:
This always trips me up also. Should be a FAQ. And perhaps the "Display
attribute..." should get enabled somehow automatically whenever an attribute
+1
Please edit the GRASS Wiki:
http://grass.osgeo.org/wiki/FAQ
or send a text snippet for (which) manual page(s) to the list.
Or write an enhancement ticket to trac:
http://trac.osgeo.org/grass/
thanks
