Hi Grass users,
I am quite new to Grass and I come here to get some hints and guidelines about
a particular problem I have.
I work on a watershed (on which I ran r.watershed, to get flow directions,
accumulation...) and inside this watershed I define a linear feature (raster
or vector) as the main stream.
I would like to calculate the distance (along the hydrographic network) of
each pixel of this watershed to the main stream. By distance I mean lenght
calculated along the flow lines defined by the flow directions. The desired
final output is a raster containing that distance to the main stream.
Has anybody done such a thing with Grass previously?
Thanks in advance,
Vincent.
Vincent Godard
Equipe de géodynamique
Laboratoire de Géologie
École Normale Supérieure
24, Rue Lhomond
75231 Paris Cedex 05, France
Tel: +33 1 44 32 22 63 Fax: +33 1 44 32 20 00
email: godard@geologie.ens.fr
I've never done it, but i guess you have to consider to use a script using r.drain with the -n option....
draft of the script:
- extract x,y coordinates of each cell of your region (basin);
- foreach point run r.drain -n input=your_dem output=your_tmp_output coordinate=x,y
- set to null the river cells in your_tmp_output by using r.mapcalc;
- run r.univar map=your_tmp_output and extract the maximum (it is the number of cells to reach the river);
- write adding in a file the x,y,max values
- end of foreach
- import x,y,z to vector
- convert vector to raster
maybe too complicate???
It is just a first idea....
Maxi
Godard Vincent wrote:
Hi Grass users,
I am quite new to Grass and I come here to get some hints and guidelines about a particular problem I have. I work on a watershed (on which I ran r.watershed, to get flow directions, accumulation...) and inside this watershed I define a linear feature (raster or vector) as the main stream.
I would like to calculate the distance (along the hydrographic network) of each pixel of this watershed to the main stream. By distance I mean lenght calculated along the flow lines defined by the flow directions. The desired final output is a raster containing that distance to the main stream.
Thanks in advance,
Vincent.
Dr. Eng. Massimiliano Cannata
Scuola Universitaria Professionale della Svizzera Italiana
Istituto Scienze della Terra
Via Trevano, c.p. 72
CH-6952 Canobbio-Lugano
Tel: +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
Godard Vincent napisa?(a):
Hi Grass users,
Markus Neteler has done something similar to what you describe.
http://grass.itc.it/grass60/screenshots/raster.php
(the "distance to water" one")
If that' what you mean, try asking him.
Maciek
