Hi Milton,
Thank you for answering,
I corrently use r.watershed to obtain my flow direction matrix (drainage). I'm searching for a module in which I can put this 'drainage' in input, and a raster (or vector) with the river network in input, to obtain in output a matrix in wich in each cell there is the distance from the river, calculated on the basis of the path defined in 'drainage'.
Thank you
m.
Milton Cezar Ribeiro wrote:
Hi Margherita,
give a look at
r.watershed
r.terraflow
r.flow
Good luck,
milton
2009/7/10 Margherita Di Leo <diregola@gmail.com <mailto:diregola@gmail.com>>
Hi Jachym,
Thank you very much for your answer.
I think I was not very clear in explaining my problem. I have to
calculate distance from a line, but the distance has to be
calculated *following a path*, defined by a matrix of direction,
as a 'flow direction' in hydrology. It would be a very useful
hydrological tool.
m.
Jachym Cepicky wrote:
would [1] help ?
[1]
http://grass.osgeo.org/grass64/manuals/html64_user/r.grow.distance.html
Jachym
On Thu, Jul 09, 2009 at 03:29:40PM +0200, Margherita Di Leo wrote:
Hi List!
I was wondering if there is a way to obtain a (raster) map
of distances from a point or a line, in which the path is
defined by a map (i.e. a flow direction).
It would be very useful for me!
Thank you in advance.
m.
Eng. Margherita Di Leo
Ph.D. Student Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
Office: +39-0971205363
Fax: +39-0971205160
E-mail: dileomargherita AT gmail DOT com
Skype: dileomargherita
URL: http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
