Greetings
I need to use a newer version of PROJ in GRASS6.4 (I have 4.6.1 and I need at least 4.6.1-5). Does GRASS6.4 supports newer versions of PROJ (even 4.7)?
Thanks
Best regards
Nikos
Greetings
Thanks
Best regards
Nikos
On Tue, Apr 6, 2010 at 4:57 PM, Nikos Dumakis <nikosdu1980@gmail.com> wrote:
Greetings
Yes. I am using 4.7.
Thanks Markus
And can it be a problem using newer versions of PROJ (4.7) with older of GDAL? (1.6.3.2) for instance supporting certain operations for newly supported EPSG systems?
Thank you all
Nikos
Greetings
at least 4.6.1-5). Does GRASS6.4 supports newer versions of PROJ (even 4.7)?Yes. I am using 4.7.
On Tue, Apr 6, 2010 at 6:04 PM, Nikos Dumakis <nikosdu1980@gmail.com> wrote:
Thanks Markus
Best asked on the GDAL list, I guess...
To be honest: I have no idea. I am using PROJ 4.7 together with GDAL 1.7
which works fine.
