[GRASS-user] does i.landstat.toar expects ALL bands to work properly?
Hello all
I’m playing around with some Landsat-8 images. After reprojecting with GDAL (for southern hemisphere), importing and clipping to a smaller area of interest, I used i.landsat.toar to convert to reflectance.
I’m only using bands 1-8.
When I run i.landsat.toar without atmospheric correction, it runs but gives me an error message about not being able to read band 9, but it does creates the images.
When I run it with atmospheric correction, I get the same error but it won’t calculate reflectance, because it stops at the dark pixel step.
So, two possibilities:
1 - If it is expecting all the bands, this should be in the manual
2 - remove this limitation, by issuing a warning but not rising an error and stopping the module.
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
Dear Carlos,
I succsessfully calculated ToA reflectance for OLI 1-8 bands with grass 6.4.4 if my memory is correct....
There are also other problems with I.landsat.toar in Grass 7 dealt with landsat 4 and 5 MSS images (the module try to calculate TOA for bands 4-7 instead of 1-4 and fail).
The other problem is that one have to rename thermal bands of Landsat 7 ETM+ images from LE......_B6_VCID_1 and 2 to LE....B_61 and 62 to succseed TOA reflectance and LST calculations.
Best regards,
Maria V. Kozlova
Information System Lab. (ISysLab)
State Oceanographic Institute,
Kropotkinsky per., 6,
MOSCOW, 119034,
RUSSIA
tel. +7 499 246 6448
fax. +7 499 246 7288
mailto: kclo@yandex.ru
29.09.2015, 17:01, "Carlos Grohmann" <carlos.grohmann@gmail.com>:
Hello all
I'm playing around with some Landsat-8 images. After reprojecting with GDAL (for southern hemisphere), importing and clipping to a smaller area of interest, I used i.landsat.toar to convert to reflectance.
I'm only using bands 1-8.
When I run i.landsat.toar *without* atmospheric correction, it runs but gives me an error message about not being able to read band 9, but it does creates the images.
When I run it *with* atmospheric correction, I get the same error but it won't calculate reflectance, because it stops at the dark pixel step.
best
Carlos
Institute of Energy and Environment - Univ. of São Paulo, Brazil- Digital Terrain Analysis | GIS | Remote Sensing -
________________
grass-user mailing list
grass-user@lists.osgeo.org
