Hello,
I'm using GRASS 7.8.6 on openSUSE Leap 15.2 and experience the
following crashes:
Welcome to GRASS GIS 7.8.6
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Z Shell (/bin/zsh)
GRASS 7.8.6 : ~ > g.version
GRASS 7.8.6 (2021)
*** Error in `g.version': double free or corruption (out): 0x000055866fc655b0 ***
[1] 9995 abort (core dumped) g.version
GRASS 7.8.6 : ~ > g.list
Lists available GRASS data base files of the user-specified data type optionally using the search pattern.
*** Error in `g.list': double free or corruption (out): 0x000055a24a9f75b0 ***
[1] 10000 abort (core dumped) g.list
Some other tools like g.gisenv work and GRASS used to work fully in the
past (using, potentially, older versions of GRASS and SUSE).
Even though these crashes occur at the end of execution (after output
was produced), they are problematic as they stop e.g. the GUI from
fully working, i.e. grass --gui brings up the launcher but crashes when
I press "Start GRASS session" with the following output (note that
there is additionally an assertion failure at the end):
Launching <wxpython> GUI in the background, please wait...
GRASS 7.8.6 : ~ > /usr/lib64/python3.6/site-packages/wx/py/buffer.py:6: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses
import imp
*** Error in `g.version': double free or corruption (out): 0x00005588157c15b0 ***
Unable to get GRASS version
*** Error in `g.version': double free or corruption (out): 0x000055ddbe4825b0 ***
File "/usr/lib64/grass78/scripts/g.extension", line 2592, in <module>
version = grass_version["version"].split(".")
KeyError: 'version'
*** Error in `g.list': double free or corruption (out): 0x000056167e0485b0 ***
File "/usr/lib64/grass78/gui/wxpython/wxgui.py", line 106, in OnInit
workspace=self.workspaceFile)
File "/usr/lib64/grass78/gui/wxpython/lmgr/frame.py", line 143, in __init__
self.notebook = self._createNoteBook()
File "/usr/lib64/grass78/gui/wxpython/lmgr/frame.py", line 330, in _createNoteBook
gcstyle=GC_PROMPT)
File "/usr/lib64/grass78/gui/wxpython/gui_core/goutput.py", line 118, in __init__
self.cmdPrompt = GPromptSTC(parent=self, menuModel=self._menuModel)
File "/usr/lib64/grass78/gui/wxpython/gui_core/prompt.py", line 138, in __init__
GPrompt.__init__(self, parent=parent, menuModel=menuModel)
File "/usr/lib64/grass78/gui/wxpython/gui_core/prompt.py", line 56, in __init__
self.mapList = self._getListOfMaps()
File "/usr/lib64/grass78/gui/wxpython/gui_core/prompt.py", line 100, in _getListOfMaps
result['raster'] = grass.list_strings('raster')
File "/usr/lib64/grass78/etc/python/grass/script/core.py", line 1288, in list_strings
mapset=mapset).splitlines():
File "/usr/lib64/grass78/etc/python/grass/script/core.py", line 503, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File "/usr/lib64/grass78/etc/python/grass/script/core.py", line 343, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None g.list --q -m type=raster ended with error
Process ended with non-zero return code -6. See errors in the (error) output.
OnInit returned false, exiting...
Error in atexit._run_exitfuncs:
wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this" failed at /home/abuild/rpmbuild/BUILD/wxPython-4.0.1/ext/wxWidgets/src/common/wincmn.cpp(478) in ~wxWindowBase(): any pushed event handlers must have been removed
*** Error in `python3': double free or corruption (!prev): 0x00005647498368e0 ***
Python versions used are 3.9.4 (local) for --text and 3.6.12 (system
wide, has wx) for --gui.
Any idea what could cause this?
Kind regards,
Maximilian
