[GRASS-user] drainage extraction - so homogeneous output across different relief conditions
Dear all,
I extracted drainage from a large number of tiles of SRTM DEMs, for several
regions of Brazil. The regions have very different relief conditions,
ranging from almost flat to very inclined. I have some cartographic maps
at scale 1:50,000, and the (reference) densities ranges from 7 to 16%.
But I was surprise that using the command below the estimated drainage
is (on my point of view) very homogeneous, ranging from 3 to 4% only:
r.watershed.exe -m --o memory=2048 elevation=srtm_map threshold=250 stream=srtm_map_drainage
Why my output map is so homogeneous accross regions with
very different terrain conditions?
Any hint are welcome.
cheers
milton
