It's my first post here. I am quite happy to join the powerful world of
GRASS. My first good impression is with the 'v.drape' process.
With the 'v.out.ogr' command, I get an issue with the dsn parameter.
I tried various syntax for dsn "path & filename" but none works fine.
v.out.ogr -e --verbose input=hidro3D@PERMANENT dsn=C:/tmp/hidro3D.shp
v.out.ogr -e --verbose input=hidro3D@PERMANENT dsn="C:/tmp/hidro3D.shp"
ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
for shapefile datastore.
v.out.ogr -e input=hidro3D@PERMANENT dsn=/c/tmp/hidro3D.shp
I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
(very bad choice).
Do you know what happens ?
In Linux Ubuntu, everything is great.
see U,
Vincent
afaik,
it should be:
v.out.ogr -e input=hidro3D@PERMANENT dsn=C:/tmp/hidro3D
On 9/17/09, Vincent Blanqué <vincent.blanque@oriondata.cl> wrote:
(very bad choice).
see U,
Vincent
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
Or you can add a name for the output file this way:
v.out.ogr -e input=hidro3D@PERMANENT dsn=C:/tmp/ olayer=hidro3D
2009/9/17 maning sambale <emmanuel.sambale@gmail.com >
afaik,
it should be:
On 9/17/09, Vincent Blanqué <vincent.blanque@oriondata.cl > wrote:
It’s my first post here. I am quite happy to join the powerful world of
GRASS. My first good impression is with the ‘v.drape’ process.
With the ‘v.out.ogr’ command, I get an issue with the dsn parameter.
I tried various syntax for dsn “path & filename” but none works fine.
v.out.ogr -e --verbose input=hidro3D@PERMANENT dsn=“C:/tmp/hidro3D.shp”
ERROR 1: Failed to create directory “C:/tmp/hidro3D.shp”
(very bad choice).
see U,
Vincent
cheers,
maning
grass-user mailing list
grass-user@lists.osgeo.org
@emmanuel :
(Thu Sep 17 11:48:08 2009) Command finished (1 sec)
But I get a Window$ bug: "v.out.ogr.exe" has stopped to work.
@kapo :
ERROR 1: Failed to create directory C:/tmp/
Thanks, both solutions does not work, I will get rid of Window$ !!!
2009/9/17 maning sambale <emmanuel.sambale@gmail.com>
afaik,
it should be:
(very bad choice).
see U,
Vincent
cheers,
maning
Since this is windows, would
v.out.ogr -e input=hidro3D@PERMANENT dsn="C:\tmp\hidro3D" olayer=hidro3D
work? Note \ instead of / in the path name.
Markus M
Vincent Blanqué wrote:
@emmanuel :
@kapo :
afaik,
it should be:
(very bad choice).
see U,
Vincent
cheers,
maning
Neither works... Windows Vista has always strange behaviour. I hate it
more and more every day. But not all the profesional software works well
in Linux. So I will keep the double boot for a while.
Thx everybody for your help,
Markus M
@emmanuel :
@kapo :
afaik,
it should be:
world of
(very bad choice).
see U,
Vincent
cheers,
maning
Hamish
September 17, 2009, 9:59pm
7
perhaps it is https://trac.osgeo.org/grass/ticket/634 ?
which was fixed in r38583 (Aug 2).
Try downloading a more recent copy of 6.4.0 if the one you had downloaded
is older than about two weeks ago. (the r37101 core library version is
not the GIS build version)
Hamish
