[GRASS-user] DTM/DEM to TIN
As far as I can see GRASS doesn’t provide any ready-to-go tool to generate TINs from grid digital elevation models. I know I can transform a grid to a regular mesh somehow (probably using the Triangle lib for the last step) but I can’t find tools to generate TINs, given a certain amount of tolerance, which preserve significative locations (like those obtained by TPI for example) and shapes (in a morphonetric sense).
Does anybody has experience on this? The general aim is generating terrain meshes (to be further decimated for LODs) to be employed in a 3D context.
giovanni
Hi.
Does the v.triangle add-on accomplish the goal?
https://raw.githubusercontent.com/amuriy/GRASS-scripts/a7df12d996abfe6461f509fce6feb6c869af2d5e/v.triangle
Mark
Hi Mark,
thanks for the reply but it’s not what I’m looking for. v.triangle is a front-end to Triangle, to generate a Delaunay triangulation on points and, eventually, breaklines.
I’m lookink for something that generates a TIN from an elevation grid (raster).
giovanni
Mark
giohappy wrote
Hi Mark,
thanks for the reply but it's not what I'm looking for. v.triangle is a
I'm lookink for something that generates a TIN from an elevation grid
(raster).
giovanni
Il 05/dic/2014 14:14 "Mark Seibel" <
mseibel@
> ha scritto:
Hi.
I can't find tools to generate TINs, given a certain amount of
by
Mark
grass-user mailing list
grass-user@.osgeo
maybe some ideas there:
http://grasswiki.osgeo.org/wiki/Triangle_Mesh
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/DTM-DEM-to-TIN-tp5176619p5176638.html
On Fri, Dec 5, 2014 at 6:01 AM, G. Allegri <giohappy@gmail.com> wrote:
As far as I can see GRASS doesn't provide any ready-to-go tool to generate
but I can't find tools to generate TINs, given a certain amount of
I'm not sure if this would fulfill your requirements but I would use
v.delaunay [1]. To get the points, you can use v.random [2, 3] or some more
clever method.
Vaclav
[1] http://grass.osgeo.org/grass70/manuals/v.delaunay.html
[2]
http://courses.ncsu.edu/mea582/common/GIS_anal_grass/GIS_Anal_grinterp1.html
[3] http://grass.osgeo.org/grass70/manuals/v.random.html
giovanni
grass-user@lists.osgeo.org
Thanks for the suggestions. I already had a look at that page, but nothing seems to fulfill my requirements.
Using v.random is not a solution. I should select significative points, and significative lines, to feed Triangle. Random selection will probably miss important locations (e.g. peaks, etc.).
giovanni
2014-12-05 15:57 GMT+01:00 Vaclav Petras <wenzeslaus@gmail.com>:
I’m not sure if this would fulfill your requirements but I would use v.delaunay [1]. To get the points, you can use v.random [2, 3] or some more clever method.
Vaclav
[2] http://courses.ncsu.edu/mea582/common/GIS_anal_grass/GIS_Anal_grinterp1.html
giovanni
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/giohappy
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
I’ve just discoevered r.refine, which seems to do exactly what I need :wink:
https://github.com/jontodd/r.refine
giovanni
2014-12-05 16:21 GMT+01:00 G. Allegri <giohappy@gmail.com>:
giovanni
Giovanni Allegri
Vaclav
giovanni
Giovanni Allegri
On 05/12/14 16:24, G. Allegri wrote:
I've just discoevered r.refine, which seems to do exactly what I need :wink:
Looks great. Maybe you can convince the author to put the code into the GRASS addons SVN ?
Moritz
2014-12-05 17:37 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
GRASS addons SVN ?
I'm tryong to contact him. No reply yet.
The GRASS code would need an upgrade because it's based on old APIs...
Moritz
Giovanni Allegri
Twitter: https://twitter.com/_giohappy_
Hi Giovanni,
A module for this would be really neat! I am not sure if this will be helpful, but here is what I have done in the past.
Set your region of interest of course. My notes indicate that I had to add an extra unit to the north and west region (not sure why).
r.out.vtk -v input=dem@PERMANENT output=dem.vtk elevation=dem@PERMANENT
# 'preserve normals' option kills Meshlab with DEM!
I then open dem.vtk in Paraview, and run the Delaney 2D filter (default options) save as .PLY file.
Next I open the resulting .PLY file in Meshlab and run Quadric based edge collapse strategy - specify desired triangles, preserve normals and I save as .OBJ file. For my needs I choose "Preserve boundary of mesh”.
Jeshua Lacock
Founder/Engineer
3DTOPO Incorporated
<http://3DTOPO.com>
Phone: 208.462.4171
