[GRASS-user] DTM with contour lines and points
Hello all,
I usually use v.surf.rst to build DTM from contour lines. However, this time I have, in addition to the contour lines, a wide range of elevation points.
How can I use isolines and points at the same time to generate the DTM?
I thought a way to get around, which is to convert the contours to equally spaced points and join these points whith the elevation points layer. Is there a more correct and straightforward way to do?
Thank you very much!
Best regards,
Pedro Venâncio
your real data are vertices anyway, so I think extracting them and
patching them with points is the straightforward way.
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
Thank you Paolo!
Best regards!
Pedro
----- Original Message -----
All the best.
Paolo Cavallini
grass-user mailing list
grass-user@lists.osgeo.org
