[GRASS-user] Duplicate vector removal
Good day,
I used the v.clean approach to snap some vectors to each other. This caused a number of vectors to lie on the same line. The rmdupl option does not seem to remove these short segments.
Any ideas on how I can get rid of them? Or perhaps I’m just using v.clean wrong. Here is the command:
v.clean input=scene01@test output=scene01_clean type=line tool=snap,rmdupl,rmsa thresh=15 --overwrite
Thanks!
Groete,
Andre Hauptfleisch
M: 082 5722 469
F: 086 687 1106
E: ahaupt@gmail.com
2007/11/20, Andre Hauptfleisch <ahaupt@gmail.com>:
Good day,
Any ideas on how I can get rid of them? Or perhaps I'm just using v.clean
rmdupl removes only *identical* features, for example
L 2 1
594233.1875 4921026.59375
596956.11875847 4921515.74307787
1 1
L 2 1
599775.5 4922022.21875
1 2
L 2 1
1 3
L 2 1
595793 4918172.46875
603426.125 4919400.40625
1 4
L 2 1
1 5
after rmdupl
L 2 1
1 1
L 2 1
1 2
L 2 1
1 3
L 2 2
1 5
1 4
First two lines 'lie' on the third one, but they are not identical, if
you want to remove them, you need to merge them first. E.g.
v.edit dupl1 tool=merge cat=1,2
remove vertex from line
v.generalize in=dupl1 out=dupl2
and then run v.clean.
The result is
L 2 3
1 1
1 2
1 3
L 2 2
1 5
1 4
Martin
Thanks!
Groete,
Andre Hauptfleisch
M: 082 5722 469
F: 086 687 1106
E: ahaupt@gmail.com
grass-user mailing list
grass-user@lists.osgeo.org
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
Thanks for the reply Martin. I thought it might have something to do with the category values.
I know it is easier said than done, but isn’t there a way one can skip the category merger part? Or can I merge all the lines into a single category? My system doesn’t require the use of category values.
I would like to automate the process. At the moment I have a raster image with some lines in them. I convert these to a vector layer, clean it up a bit and output it to svg.
Andre
On Nov 20, 2007 2:03 PM, Martin Landa <landa.martin@gmail.com> wrote:
Good day,
rmdupl removes only identical features, for example
L 2 1
1 1
L 2 1
1 2
L 2 1
1 3
L 2 1
1 4
L 2 1
1 5
after rmdupl
L 2 1
1 1
L 2 1
1 2
L 2 1
1 3
L 2 2
1 5
1 4
First two lines ‘lie’ on the third one, but they are not identical, if
The result is
L 2 3
1 1
1 2
1 3
L 2 2
1 5
1 4
Martin
Thanks!
Groete,
Andre Hauptfleisch
M: 082 5722 469
F: 086 687 1106
E: ahaupt@gmail.com
Groete,
Andre Hauptfleisch
M: 082 5722 469
F: 086 687 1106
E: ahaupt@gmail.com
Hi Andre,
I know it is easier said than done, but isn't there a way one can skip the
My system doesn't require the use of category values.
not sure if I understand well, you can remove categories after
cleaning vector map layer
v.category opt=delete
Martin
Andre
> Hi,
> > Good day,
caused
seem
v.clean
> L 2 1
> 1 1
> L 2 1
> 1 2
> L 2 1
> 1 3
> L 2 1
> 1 4
> L 2 1
> 1 5
> after rmdupl
> L 2 1
> 1 1
> L 2 1
> 1 2
> L 2 1
> 1 3
> L 2 2
> 1 5
> 1 4
> The result is
> L 2 3
> 1 1
> 1 2
> 1 3
> L 2 2
> 1 5
> 1 4
> Martin
> > Thanks!
> > Groete,
> > Andre Hauptfleisch
> > M: 082 5722 469
> > F: 086 687 1106
> > E: ahaupt@gmail.com
> > _______________________________________________
Groete,
Andre Hauptfleisch
M: 082 5722 469
F: 086 687 1106
E: ahaupt@gmail.com
