-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 31/08/2013 14:04, Markus Neteler ha scritto:
I'm encountering problems with subsequent v.overlay, and I suspect duplicated CATs
may be the cause.
can you please post the relevant column info output of "ogrinfo yourmap"?
which map? The original before import? Here it is:
Layer name: test_import
Geometry: Polygon
Feature Count: 2
Extent: (1570773.587980, 4879203.434159) - (1579628.292941, 4890270.180298)
Layer SRS WKT:
PROJCS["Monte_Mario_Italy_zone_1",
GEOGCS["GCS_Monte Mario",
DATUM["Monte_Mario",
SPHEROID["International_1924",6378388,297]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",1500000],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
COD_COMPON: String (6.0)
COMPONENTE: String (200.0)
COD_SUB_CO: String (10.0)
SUB_COMPON: String (200.0)
NUM_ELEMEN: String (4.0)
NUM_SIST_E: Integer (10.0)
NUM_TAV: Real (24.5)
NORMA: String (200.0)
SCHEDA: String (200.0)
ID1: Integer (10.0)
OGRFeature(test_import):0
COD_COMPON (String) = LAG
COMPONENTE (String) = LIGURIA AGRICOLA
COD_SUB_CO (String) = AGR
SUB_COMPON (String) = AREE AGRICOLE
NUM_ELEMEN (String) = (null)
NUM_SIST_E (Integer) = (null)
NUM_TAV (Real) = 51.00000
NORMA (String) = \\rivu\dtuff\img\ptr\norme\LAG.pdf
SCHEDA (String) = (null)
ID1 (Integer) = 5
MULTIPOLYGON (...
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlIiIqEACgkQ/NedwLUzIr54EgCgpBce4LzxuHWJhkx/TgwSyL2k
VdIAniscwHf88szQsgLxIqtNPXoRFvEi
=Zj+c
-----END PGP SIGNATURE-----
