how can I transform a dxf (imported with v.in.dxf) layer in utm32 coordinates system? I am currently doing some trials with v.transform with no success.
Arranging xshit and yshift leads me near the desired result but there’s still a rotation problem I can’t solve (it seems to me at least)
Is the dxf in some coordinate system?
If yes, then make a location based on that CRS, import the dxf into that location, then v.proj inot the UTM location.
If not, then make an X-Y based location, import the dxf there, then again v.proj into your UTM location.
I have created an XY based location but whe using v.proj grass fails complainig about PROJ file not found… so still stucked
Opening the dxf (converted using dxf2shp plugin) in Qgis reports that is a “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”
Hello,
be care full with QGIS layer CRS definitions. By default QGIS will
assign WGS84 as layers CRS if layer lacks CRS definition or definition
is bogus. Use ogrinfo -ro -so MyFile to check files CRS. Still IIRC
DXF doesn't contain CRS definition - You have to look into metadata
provided with Your DXF file (if You have metadata) or do Your best
guess based on DXF data location (i.e. DXF file from Latvia most
likely will contain data in LKS-92/TM CRS).
If You are interested in transforming DXF ?? to UTM, You can also try
to use ogr2ogr and then import result into GRASS for
analysis/processing. ogr2ogr provides -s_srs option where You can
specify source CRS.
no success.
complainig about PROJ file not found... so still stucked
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
If your dxf is in a local coordinate system (like old topo drawings) with shifting parameters you can use v.transform or you can put it in place with a CAD software (align) and them import into GRASS.
If it already have an utm coordinate and you want to change the reference system (datum) create the coresponding location import, change location and them v.proj (should be no problem).
I work with a lot of CAD drawings and charts with GRASS and here is a very usefull advice:
The fundaments of areas, boundary and lines in CAD and GIS are different, before importing a drawing into a GIS try to make it clean and “GIS like”, ex. make two areas share the same boundary. Also import only the objects of interest, do not import text, paper layout or hatches.
Hello,
DXF doesn’t contain CRS definition - You have to look into metadata
specify source CRS.
no success.
On Wed, Nov 18, 2009 at 10:33 PM, Pablo Carreira
usefull advice:
before importing a drawing into a GIS try to make it clean and "GIS like",
