William, thanks for your reply.
on 7/16/08 10:44 PM, William Kyngesburye at woklist@kyngchaos.com wrote:
Sorry, I missed your first message. I realize that I include gpsbabel
1.3.4 in my GRASS, though 1.3.5 is in my todo list. I don't think
v.in.gpsbabel has a problem, it's gpsbabel itself.
When you say you updated to gpsbabel 1.3.5, where did you get it or
did you compile from source?
I downloaded the installer from gpsbabel.org (for Tiger and Leopard).
It almost looks like you got a gpsbabel binary that was compiled on
Leopard (10.5) - Leopard includes /usr/lib/libexpat, but Tiger does
not. Also, it looks like you replaced the gpsbabel in my GRASS binary
with your updated one.
I did not (intentionally) replace your version of gosbabel in the GRASS
binary. My recollection of events is that 1) I upgraded to Lorenazo's GRASS
version 6,3,0 from an older version, 2) I updated to the gpsbabel.org
GPSBabel 1.3.5, and 3) I installed your 6.3.0-1 (Tiger).
The gpsbabel I include in my GRASS binary has libexpat built into it
so there is no need to worry about that. Try restoring my gpsbabel,
or is there a specific need for the new 1.3.5?
I do not have a specific need for GPSBabel 1.3.5. I deleted the installer
receipt for your GRASS version and reinstalled 6.3.0-1 [same problem]. I
then downloaded and installed your 6.3.0-2 [same problem]. I also tried
commenting the gpsbabel path out of my $PATH statement [same problem].
When I view the contents of your GRASS package, the version of gpsbabel has
a modification date of 7/3/08 (8:15p). The version 1.3.5 from gpsbabel.org
has a modification date of 5/4/08.
I only get the dyld library error when I use GPSBabel from within GRASS
without an explicit path; it works fine when I use an explicit path to the
gps.babel.org version or when I use a fresh (non-GRASS) Terminal session.
On Jul 16, 2008, at 9:06 PM, Dwight Needels wrote:
on 7/11/08 12:03 PM, Dwight Needels at needels@translucida.com wrote:
I get an error when I try to run v.in.gpsbabel...
v.in.gpsbabel -t input=/Users/dwight/t_Westfield.gpx output=Westfield
format=gpx
Loading Tracks from </Users/dwight/t_Westfield.gpx>...
dyld: Library not loaded: /usr/lib/libexpat.1.dylib
Referenced from: /Applications/GRASS-6.3.app/Contents/MacOS/bin/
gpsbabel
Reason: image not found
/Applications/GRASS-6.3.app/Contents/MacOS/scripts/v.in.gpsbabel:
line 283:
27874 Trace/BPT trap
gpsbabel $TYPE -i $GIS_OPT_FORMAT $GPSdevice $PROGVERBOSE -o gpx -F
"$TMP".gpx
ERROR: Error loading data from gpsbabel
I have done this in the past without any problem, but four things
that have
changed since the last time I tried are: (1) upgraded to GRASS
version 6.3,
(2) switched from Lorenzo¹s binary to William Kyngesburye¹s, (3)
upgraded to
GPSBabel 1.3.5 and (4) switched to use SQLite instead of DBF.
From within a GRASS session, attempts to use gpsbabel to convert a
track to a
route fail with the same dyld: Library not loaded message, but not
if I use an
explicit path to my installed version of gpsbabel. It is in my
PATH, and works
fine if I run it from a fresh Terminal session. Does this mean it
is an issue
with gpsbabel within the GRASS package?
Any ideas on how I can fix this?
GRASS 6.3cvs
gpsbabel 1.3.5
Macintosh PPC
MacOS X 10.4.11
-Dwight
Does anyone have any ideas for how I can get g.in.gpsbabel to work?
-Dwight
grass-user mailing list
grass-user@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
Any other ideas? Thanks, -Dwight
