[GRASS-user] E-OBS climate data and TGIS in GRASS
Anyone ever tried to import the E-OBS climate data [1] into GRASS temporal
framework?
Some hints to share?
[1]
http://eca.knmi.nl/
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/E-OBS-climate-data-and-TGIS-in-GRASS-tp5257384.html
Hi Helmut,
Which particular dataset there you want to use?
There is a presentation from Soeren at 2012 GEOSTAT course [0] in which he uses one of ECAD datasets as example. Maybe useful?
What are you interested in doing, if I may ask?
Vero
[0] http://www.geostat-course.org/system/files/Presentation_0.pdf
ยทยทยท
2016-03-19 14:36 GMT-03:00 Helmut Kudrnovsky <hellik@web.de>:
framework?
[1]
http://eca.knmi.nl/
best regards
Helmut
grass-user mailing list
grass-user@lists.osgeo.org
Hi Veronica,
uses one of ECAD datasets as >example. Maybe useful?
thanks for the hint!
http://eca.knmi.nl/download/ensembles/download.php#datafiles
daily mean temperature TG,
daily minimum temperature TN
daily maximum temperature TX
daily precipitation sum RR
what are you interested in doing, if I may ask?
I have vegetation samples across Europe, from the North to the South, from
the West to Caucasus. as this vegetation types are sensitive to temperature
and precipitation, such parameters may be included in ecology pattern
analysis.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/E-OBS-climate-data-and-TGIS-in-GRASS-tp5257384p5257393.html
framework?
[1] http://eca.knmi.nl/
Here is a tutorial by Soeren Gebbert:
The temporal GRASS GIS framework: Introduction and application
http://geostat-course.org/Topic_Gebbert
--> http://www.geostat-course.org/system/files/Presentation_0.pdf
Slides 52 to end
cheers
On Sat, Mar 19, 2016 at 9:01 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
Hi Veronica,
ECA&D contain some serious errors:
1. look at the spatial distribution and location of the stations used
http://eca.knmi.nl/download/ensembles/data/ensembles_tg_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_tn_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_tx_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_rr_stations_v12.0.txt
2. calculate annual averages and check if they match your
expectations. They did not match my expectations (and those of my
group) so we decided to ditch ECA&D.
analysis.
If possible, use a datasource different from ECA&D.
Markus M
best regards
Helmut
Markus Metz-3 wrote
On Sat, Mar 19, 2016 at 9:01 PM, Helmut Kudrnovsky &lt;
hellik@
&gt; wrote:
Hi Veronica,
he
from
temperature
analysis.
thanks for the insigth to this dataset.
do you have any recommondations for alternatives regarding Europe?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/E-OBS-climate-data-and-TGIS-in-GRASS-tp5257384p5257891.html
