[GRASS-user] East/West Horizons Giving Negative Numbers
Hello Everyone!
I’m a grad student who is relatively new to GrassGIS and I was wondering if someone here can help me figure out what’s wrong with my east and west horizon calculations?
I am trying to compute my east and west horizon angle from my DEM using the command r.horizon. My output raster contains negative numbers and it’s my understanding that the range of output values should be between 0 and 360. I used -d to make sure that my output is in degrees rather than radians.
Can anyone help me solve this problem? Or point me in the right direction?
Thank you for the help!
Ashley
Here is the r.info output from my generated east horizon raster.
| Type of Map: raster Number of Categories: 0 |
| Data Type: FCELL |
| Data Units: degrees Vertical datum: (none) |
| Rows: 7532 |
| Columns: 5860 |
| Total Cells: 44137520 |
| Projection: UTM (zone 10) |
| N: 4543151.24515692 S: 4317194.98362237 Res: 29.99950366 |
| E: 759846.34683197 W: 584057.70444841 Res: 29.99806184 |
| Range of data: min = -90 max = 78.47394 |
| Data Description: |
| generated by r.horizon |
| Comments: |
| r.horizon -d elevation=“dem30m@PERMANENT” direction=0 start=0.0 end=\ |
| 360.0 output=“east” distance=1.0 file=“-” |
| Horizon view from azimuth angle 0.00 degrees CCW from East |
