[GRASS-user] Easy way to patch vector files
Stephen -
Adding an attribute table to the input map is probably the best thing to do!
You can create the patched vector with no attribute table, and add it later - but you'll then have to go back and use other tools to create a table and fetch attributes from the original.
cheers,
Richard Chirgwin
On 10/11/12 7:00 AM, grass-user-request@lists.osgeo.org wrote:
I have two different vectors that I would like to patch together. one
doesn't have an attribute table associated with it. The other does. I
am having a problem figuring out how to get them to play nicely. At
this point It would be easier to just create an attribute table... All
help is greatly appreciated. I will provide any information that you
all need to help. Many thanks in advance.
