Hello
I'm still a neophyte in GRASS. And I have two questions:
1 / I'm on Ubuntu 10 and Grass6.4 since two days and I try to open the
training ECW orthophotos with GRASS. Does someone could give me the
procedure
thank you
Hello
procedure
thank you
procedure
have a look here
http://trac.osgeo.org/ubuntugis/wiki/UserTutorials
cheers
-- Giovanni --
hello
I just tested the procedure, and the package gdal-ecw-src is not found …
thank you
Cordialement
Etienne DELAY
Deust "Webmaster et gest. d'intranet" (IDSkype : etienne.delay.tic)
Master IUP "valorisation du patrimoine et aménagement du territoire"
found ...
the library is called
libgdal-ecw-src
cheers
-- Giovanni --
again
in root a make
apt-get update && apt-get install libgdal-ecw-src
an erreur
E: Impossible de trouver le paquet libgdal-ecw-src
... so I dont know
see you :-)
Cordialement
Etienne DELAY
again
in root a make
apt-get update && apt-get install libgdal-ecw-srcan erreur
E: Impossible de trouver le paquet libgdal-ecw-src... so I dont know
see you
did you added the ubuntugis-unstable ppa repository?
I believe the package is part of that particular repository.
cheers
-- G --
Le 09/07/10 17:36, Giovanni Manghi a écrit :
again
in root a make
see you
did you added the ubuntugis-unstable ppa repository?I believe the package is part of that particular repository.
cheers
-- G --
I believed but no...
So now I have make
and it's ok
But I'm a linux noobie, so what can I make now?
see you again
Cordialement
Etienne DELAY
