I was trying to edit one of my point vector dbf files in the file PERMANENT/dbf. I used the spreadsheet in Openoffice to adjust a .dbf file. The STR_1 column originally read #1 %64 @"Cat. 64". I needed the Cat. 64 for a label on my map so I edited the column to read just Cat. 64. Now when I resize the size of the Map Display Window, everything freezes. If I leave the map display window alone I can work with the project a little, but GRASS (or WISH) unexpectedly quits, usually sooner rather than later. I tried to at the #1 %64 with the quotation marks back, but this didn't help. Can anyone tell what the problem is and how to fix it? Since I am using Qgis to do the actual displaying (and it doesn't seem to have the problem) I'll be fine, unless I have to adjust something in GRASS. Then I will need a back up plan.
Thanks for any insight that people may have.
Kurt
up plan.
Kurt
Hi Kurt,
I (and others on the list) have encountered a variable degree of
success when working with DBF files opened/saved by an external
program. In some cases it works, in others the datatype (or something)
of a column will change and all hell breaks loose. I have seen this in
both GRASS and ESRI programs -- it just seems like the DBF file format
is very fragile. If possible, try converting your database back-end to
SQLite-- there are many good GUI-based tools for working on SQLite
files, and the SQLite engine has full support for SQL. It can be a
pain to switch between database back-ends, but I wish that I had done
it sooner.
Good luck,
Dylan
grass-user mailing list
grass-user@lists.osgeo.org
The dbf file started life as an ascii file written in Textwrangler. I converted via v.in.ascii. The code I used was reminiscent of what I use to use to create a site using s.in.ascii. I couldn't find out if the codes changed for v.in.ascii.
I have tried using various databases for my archaeological sites, without success. I tried following the book but I must be missing something. I have SQLite Browser, it seems easy to use, but I have trouble connecting it. (I haven't touched it in a while.) How do you set up the columns for easting and northing (UTM). What about other kinds of data (in this case the Catalog number). Then how do you make it display as a point vector (in this case). The GRASS book is a little vague, when I need a step by step approach.
Thanks for your help.
Kurt
up plan.
Kurt
Hi Kurt,
it sooner.
Good luck,
Dylan
