[GRASS-user] editing grass postscript maps
I'm working on getting my GRASS maps ready for publication. I've
worked my way through ps.map successfully, with eight nice maps. I'd
like to make a single plate with all eight maps. I usually do my
graphics editing with Gimp or Inkscape. However, in Gimp the maps are
very grainy, which I imagine is a consequence of their being converted
from ps to bitmap format. When I try to open them in Inkscape the
vectors come out nice and clear, but the raster layers are completely
absent. I've tried opening them, importing them, and converting them
to svg manually using pstoedit, all with pretty much the same result.
My questions are:
Is there a way to make a multi-map plate directly in GRASS, or
What is the recommended way to manipulate the ps files outside of
GRASS to achieve this? I'm using Debian GNU/Linux, so have ready
access to lots of graphics programs, if anyone can recommend something
better than what I've tried.
Tyler
Who is your computer working for?
http://www.defectivebydesign.org/faq
how about concat-ing the figures into a single PS file, then converting to a
PDF with 8 pages per sheet ?
I know that many KDE apps can do this in the print options -- which probably
just invoke gs with some magic incantations...
cheers,
dylan
On Tuesday 15 May 2007 12:53, Tyler Smith wrote:
My questions are:
Tyler
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
You could try a combination of 'psmerge' and 'psnup' programs, both from
the package 'psutils'. Both work from the command line.
Or if you have produced eps-files, perhaps epstopdf -> pdfjoin -> pdfnup
-> pdftops.
Harri K.
psutils (http://www.tardis.ed.ac.uk/~ajcd/psutils/index.html), in particular the psnup command, can do this to PostScript without any conversion - I've used it sucessfully many times, although the last was quite a few years ago now. Perhaps it is installed by default on Debian?
But I was assuming there'd be a need to put extra captions and stuff under the maps and re-arrange them on the page, which psnup won't do. I'd say definitely the Inkscape approach is the one to go with from this point of view; perhaps it's worth investigating in more depth what the problem with it is (e.g. look at the raw postscript text where the image is included or something - try it with images from the new GRASS postscript display driver and compare results or something) before spending a lot of time looking at alternative solutions?
Paul
cheers,
dylan
My questions are:
Tyler
Dylan Beaudette
530.754.7341
grassuser mailing list
grassuser@grass.itc.it
latex ???
> to a PDF with 8 pages per sheet ?
Paul
> probably just invoke gs with some magic incantations...
> cheers,
> dylan
>> Hi,
>> My questions are:
>> Thanks,
>> Tyler
> Dylan Beaudette
> 530.754.7341
Dylan Beaudette
530.754.7341
Not with ps.map. The new 'd.out.file format=ps' + d.frame might work.
> something better than what I've tried.
converting to a PDF with 8 pages per sheet ?
a2ps --landscape --columns=4 --rows=2 -o outfile.ps [FILE(s)]
or maybe just
a2ps -8 -o outfile.ps [FILE(s)]
ps2pdf13 outfile.ps
I think you can pass it multiple input file without having to use cat
first.
Hamish
>a
psnup is ok, but there is no direct way to control the spacing between
the original ps files, at least not that I can find. I've not got a
nice 2-column layout, but with big gaps betwen the columns and rows of
images, which will be a deal-breaker trying to get this published. The
actual code I used was:
psmerge -omerge.ps *.ps
psnup -m1in -w8.5in -h11in -W3in -H2in -8 merge.ps psnupped.ps
All I need is a letter in the corner of each plot, which ps.map will
do without much bother. The captions will be done in LaTeX.
I'd say
um, yeah. I looked at the raw postscript code and confirmed that I do
in fact have no knowledge of even the most basic structure of
postscript code.
I have just now figured out what I was doing wrong with the Gimp. I
was opening the .eps files I had generated with ps.map at 300dpi, but
the base layer was only 100dpi, so the resolution was 100dpi in the
final image. Now that I know that, it looks like I should be able to
get clear, if very large, images out of the gimp after all. So if I
can't get inkscape to display the raster layer in lovely colour, at
least I can get a usable image out of that, at least for my thesis.
Tyler
Paul
>probably
>cheers,
>dylan
>>Hi,
>>My questions are:
>>Thanks,
>>Tyler
>Dylan Beaudette
>530.754.7341
>_______________________________________________
Friends don't let friends send Word documents
http://www.nothingisreal.com/dfki/no-word
Paul:
> on Debian?
Tyler:
a2ps --margin[=NUM]
       define an interior margin of size NUM
> do.
I've just put up a new example in the d.out.file help page demonstrating
this for the new PS driver.
one trick how to do that nicely: open it at 1200dpi or so, then rescale
down using the rescale tool (Shift-T) + Cubic interpolation. May or may
not give you better results than going to the target size directly from
the File->Open dialog. But you will only lose resoution resampling to
raster, so try hard for a PSutils solution first.
Hamish
On 15/05/07 21:53, Tyler Smith wrote:
You've received many other valid recommendations, but as ultimate solution you could also export vector and raster layers separately and the put them back together in inkscape.
Moritz
On Wed, May 16, 2007 at 05:49:28PM +1200, Hamish wrote:
a2ps --margin[=NUM]
a2ps was a bust for me. My individual maps are 3"x2" landscape-layout,
and I want them printed on a single letter-size page in portrait
layout. I couldn't get anything close to that with a2ps.
Ok, my solution to this problem, preserved here for posterity, is as
follows:
Generate the maps. Script pasted below.
Combine the maps:
psmerge -omerged.ps *.ps
Arrange the maps on a single sheet:
psnup -s1 -m0.01in -b0 -w5.5in -h7in -W2.73in -H1.75in -8 \
       merged.ps psnupped.ps
The -s1 flag was critical - otherwise psnup kept trying to rescale the
individual images, which added lots of ugly whitespace around them.
Before I added the -m flag no bounding box was generated, and latex
couldn't process the file.
The output of psnup was fine but for one thing. The bounding box was
listed as if there was only one 3x2 map, not a 5.5x7
composite. Inserting this into Latex meant that all placement commands
operated as if only the bottom left map was there, resulting in
chaos.
Opening up the .ps file I found that the bounding box information was
on line three, and despite knowing nothing of postscript I guessed
correctly what was necessary:
tyler:geography-> head -3 psnupped.ps
%!PS-Adobe-3.0
%%Pages: 1 0
%%BoundingBox: 0 0 196 126
tyler:geography-> cat psnup.head
%!PS-Adobe-3.0
%%Pages: 1 0
%%BoundingBox: 0 0 400 510
                   ^^^ ^^^ corrected values
Of course, the output of psnup was too big to be opened in emacs, so I
had to cut the head off it, cut the tail off it, modify the head, and
then put them all back together:
tyler:geography-> tail -n +4 psnupped.ps > psnuptail.ps
<edit psnup.head in an editor>
tyler:geography-> cat psnup.head psnuptail.ps > psnupbb.ps
I found out the hard way that doing this in one step was a recipe for
disaster:
tyler:geography-> cat psnup.head $(tail -n +4 psnupped.ps) > psnupbb.ps
After 30 or 40 minutes of constant swapping I killed that (with some
difficulty) and did it as three separate steps, which completed in a
few minutes.
The actual size of the files became an issue. Each of the eight maps
was 100MB, and the merged file was ca. 500MB. Half-way through the day
I ran into the problem that my 27GB home partition was stuffed full,
with more than 5GB taken up by failed postscript experiments. Much of
the rest of the space is taken by larger raster datasets - if only I'd
known GIS was going to be like this I'd have bought a bigger harddrive!
Anyways, I've got what I need, and it only took my twice as long as I
thought it should take.
Thanks for your suggestions, and let me know if you can think of any
other ways to improve on my very ugly solution.
Tyler
Here's my ps.map script, to be complete:
#!/bin/bash
lab_num=41
for map_name in aest_90 bush_90 carol_90 comp_90 \
    hirs_90 roan_90 swan_90 vir_90;
  do
  lab_let=$(echo -n $(printf "\\x$(echo $lab_num)"))
  echo "paper
  top 0 inches
  bottom 0 inches
  right 0 inches
  left 0 inches
  width 2.73 inches
  height 1.75 inches
  end
  text -63 27 $lab_let
  fontsize 12
  font Helvetica-Bold
  end
  vlines na_bound
    type boundary
    color black
    width 0.5
  end
  grid 15
    cross 0.5
    numbers 1
    width 1
    fontsize 6
  end
  raster $map_name
  end" | ps.map output=${map_name}.ps ;
  echo $((lab_num++)) > /dev/null ;
  done
It is possible to multiple-map composition in GMT, you could give that a try
next time... ?
cheers,
Dylan Beaudette
530.754.7341
was 100MB,
Ouch.
Next time, you might want to use "g.region res=" to reduce the size of
the raster data. 100MB is ~16 million pixels @ 6 bytes/pixel (RRGGBB).
Looking at the "paper" command:
  width 2.73 inches
  height 1.75 inches
2.73 * 1.75 = 4.7775 sq.in.
100e6 / 6 = 16666667 pixels
16666667 / 4.7775 = 3488575 pixels/sq.in.
sqrt(3488575) = 1868 pixels/in
Even if the printer does 2400 DPI, the halftone resolution is going to
be a fraction of that, so you could reduce the resolution
substantially without seeing any noticable difference.
I doubt that there's much point in going above 300 DPI (around 1/6th
of what you appear to have) for a raster; 2.73" * 1.75" @ 300 DPI
would be 819 * 525.
  width 2.73 inches
  height 1.75 inches
would be 819 * 525.
So, if g.region -p tells me:
nsres: 0:00:30.0024
ewres: 0:00:30.0024
To reduce the resolution by 1/6 I would do:
g.region res=0:03:00.0000
Is that right?
I'll give it a try...
Done!
My completed figure is now 16MB instead of 500MB, and it looks fine!
Wish I'd known about g.region res before -- next time it will be
much easier, and will take a lot less time and disk space.
Tyler
Tired of spyware? Try Firefox:
www.firefox.com
