[GRASS-user] Editing Saved Workspace
Hello, Dear GRASS Users.
I am working with GRASS 7.0.4 (Win10-64bit) and got a problem with saved workspaces (*.gxw files). After saving a GRASS session as a workspace and re-opening the respective *.gxw file, the saved layers appear but it is not possible to edit them. The layers can not be marked or clicked. New layers (vector or raster layer) added to the same workspace are also not editable. However, creating a new GRASS session with the same layers works fine.
Are there any ideas how this problem can be solved?
Thank you very much for your help.
Martin
works fine.
this is fixed in newer versions [1], please update to a newer version for
your operating system:
https://grass.osgeo.org/download/software/ms-windows/
[1] https://trac.osgeo.org/grass/ticket/3505
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
[please keep discussion always in the ML, that also others are able to Help]
Anyhow, I followed your advice and installed the latest stand-alone
version available for download which is WinGRASS-7.5svn-r72586->109. The
installation process was running without any problems but when I >tried
to open GRASS I got the following error message: "zstd.dll is >missing".
Open a ticket about the missing zstd dll in the standalone winGRASS 7.5.svn
installer.
in the meanwhile, you can use winGRASS also via OSGeo4W
https://trac.osgeo.org/osgeo4w/
best regards
Helmut
Help]
7.5.svn
installer.
for the record, ticket opened:
https://trac.osgeo.org/grass/ticket/3543
best regards
Helmut
