[GRASS-user] Elevation values display
The bathymetric data have depths (z values) as integers. When displayed in
the GUI display window they are floating point values each ending in .00. I
don't find where that's controlled. Since they're close together I'd like to
display only the integer portion of each value.
Can I do this?
Rich
Hello, try doing double click on the legend (in pointer mode) to set object properties. You can set the number of digits after decimal point (zero in your case).
Cecilia
El sáb, 2 de oct. de 2021 a la(s) 16:51, Rich Shepard (rshepard@appl-ecosys.com) escribió:
don’t find where that’s controlled. Since they’re close together I’d like to
Can I do this?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Cecilia,
Thanks for the suggestion. These numbers are the z values. Their color can
be changed with the label color option but there's no legend when a value is
double clicked; the easting/northing values are displayed in a popup window
and I can copy them to the clipboard or otherwise save them.
Rich
