On Thursday 01 February 2007 08:27, temiz wrote:
Dylan Beaudette wrote:
> On Wednesday 31 January 2007 05:14, Markus Neteler wrote:
>> temiz wrote on 01/31/2007 06:53 PM:
>>> hello
>>> Can you make a suggestion about how I can find the highest and lowest
>>> elevation points of all watershed basins
>>> as vector points ?
>>> I mean, I have watershed map as vector. I need it's table includes
>>> like "cat", "highest elevation value", "lowest elevation value"
>>> How can I do that ?
>> If I understand your question correctly, you can do this easily with
>> v.rast.stats
>> Description:
>> Calculates univariate statistics from a GRASS raster map based on
>> vector objects
>> The help page contains a similar example.
>> cheers
>> Markus
> If you have problems with this approach (no reason to suspect problems),
> I have found that 'starspan' coupled with GRASS to be an excellent
> raster+vector reporting tool.
> main idea:
> start grass
> starspan --vector location/mapset/vector/yourvector \
> --raster location/mapset/cellhd/your_raster \
> --stats output.csv min max avg mode (...)
> Output is saved to a CSV file, not quite as nice as v.rast.stats saving
> results back to the attribute table though... The nice thing about this
> approach is that the raster and vector sources can be any GDAL-readable
> data type. For example, I use starspan to compute raster statistics
> within a given radius of a set of points. The raster files are all stored
> in GRASS, and the points are stored in PostGIS.
> Cheers,
/*thank you
Hi Ahmet,
/*I have never met */starspan so far. I am looking at its home page and
it will certain to be very useful.
I will work on it.
Be sure to, it is a simple compile from source code if you have both GDAL and
GEOS installed with their include files.
As I see, you are a soil scientist, so you will understand me better.
possibly...
The logic of my question is based on finding slopes' length as landslide
susceptibility parameter ( I accept slope is waterhed area).
so: landslide susceptibility ~ f( slope length ) --> this is a simple
raster-based operation: calculate the upslope contributing area for each cell
of a DEM. Check the literature for ideas.
I am not entirely sure I understand what you are trying to do... Are you
trying to estimate a landslide potential for each watershed boundary polygon?
Firstly, I used PostGis's extent function and got width and length of
polygons (say watershed or landslide as polygon). But this
polygon's longest dimension doesn't fit dimension in downslope
direction, which is the slope length I am looking for. So, if I found
max and min values of elevation of the polygons, I could calculate
slopes' length.
This does not sound like a realistic solution, as the extent() function will
return a minimum bonding box -- which provides the maximum 'length'
and 'width' of some polygon, but not much useful information.
/*v.rast.stats */gives max and min values of elevation of the polygons(
/*v.rast.stats*/ has still been running for most 20 hours).
maybe from these values I generate vector points containing min & max
values .
Do you have a number of polygons, and the specifications for your DEM: cell
size, region size? You may have hit some upper boundary for v.rast.stats.
Starpan seems to scale very well, so you may not run into this problem.
I will appreciate if you supply your ideas and recommendations
regards
Sure. With a clearer statement of the problem, and some information on your
source data it may be possible to come up with a workable solution.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
